amp cutting out issue! i need help
Results 1 to 3 of 3
    Senior Member bartel's Avatar
    Mar 2010
    Default amp cutting out issue! i need help
    So i am running a 6 channel JL audio amp for my mids and highs. I also run a mono amp to run my two 12s.
    here is my issue. sometimes the stereo works great all day. Other times the JL amp cuts out and all i get is my subs. then if i turn the volume knob all the way up and back down again a few times my JL amp will kick back in and all the speakers will start working again.
    does this sound like an amp problem or should i start with replacing the head unit.
    and since we are on teh topic i am running a JL amp in my truck to power my two 10s and it does the same damn thing. do i have an imput signal level set wrong or a loose wire or what? Both of these amps used to work just fine. They both started doing this this summer and i have not changed anything to do with the stereo in a few years.
    2006 22ft Placecraft 496 Mag
    Junior Member Nmliberator's Avatar
    Feb 2013
    Could be to much load on the amp and it goes into protect mode.
    Mar 2010
    that is what i thought. but it has not been adjusted in a few summers and it used to work just fine!
