Sub location issue ?
Results 1 to 5 of 5
    Junior Member gapple12's Avatar
    Nov 2013
    Default Sub location issue ?
    Hey Guys, I'm new here. Just picked up my first boat ( Monterey 190 ) and getting ready to put in a new sound system. My problem is sub-woofer location. My only real option is in the back engine compartment, which has tons of room, with a 12" sub for enough airspace. I MAYBE could fit an 10" or 8" Sub under the drivers console and a small box, but then leg room could suffer. The engine compartment has 4 air escapes for ports, 2 going forward along the side and 2 heat exits in the rear. I'm curious if I will be able to hear it good being inside there ? All my friends have theirs out in the open and they rock, Ive never seen one in a compartment. THANKS !!!
    Nov 2013
    Pic below shows where the front air vents are for the engine compartment and rear air exits.
ID:	412866   Click image for larger version.
    Senior Member Wizard's Avatar
    Put them under the console. If you put them in the engine compartment the output will be greatly reduced.
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    What he said, under console. Tried installing 2 solo baric 12s in a back hatch of a friends comp ski boat, had air vents into passenger area. Even with over a 1000 watts rms wasn't very loud unless hatch was open. I recommend a good slot port enclosure. 10s rock pretty hard with enough power, even if its only one.
    Sent from my RM-917_nam_usa_214 using Tapatalk
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Dec 2009
    Sac, Ca
