Place Diverter Nozzle Kits!!!!!
Results 1 to 9 of 9
    World's #1 Jet Drive BerkeleyJet's Avatar
    Cool Place Diverter Nozzle Kits!!!!!
    "Start Berkeley Original, Stay Berkeley Original!"
    Senior Member 78Eliminator's Avatar
    whats the price for just the nozzle and the cable?
    151-25100 JC/JG Nozzle Only $418.99
    620-46015 43BC Cable $78.99
    Give me a call when ordering and I will hook you up with a FREE Berkeley T-Shirt!
    Brad
    cool and thanks. One question. will this fit a dominator split bowl?
    Senior Member TahitiRat's Avatar
    Fort Worth Texas
    Whats the floor mount control cost
    Quote Originally Posted by TahitiRat View Post
    PM sent.
    Chantilly Va.
    Default Holeshot
    So,I have a 12JG,. I have a droop right now.What do I need to do an installation. I have a 19 foot gullwing that I cannot just hammer the throttle from a stand, the bow rises and it cavitates,Then I realize this wont get it.I have to slowly bring the bow down.Then it will take "SET", at which time I can hammer the throttle..Will this install make this better? As I understand, I can set the nozzle in the full down position,Hit the throttle, get the boat to take a "SET",then play with the "UP" position ,then set an "UP" stop. If this is accurate, I am WAY interested in going this route.Thanks for your time.Jack .P.M. me if that is O.K. with you.Again,Thank You for your time.Sounds to me ,like post # 3 says $500.00 +/- sets me in the range, close? After re-reading post# 3,gonna need a lever too.
    Quote Originally Posted by sunkisst View Post
    Place Diverter is the ultimate upgrade for your Berkeley 12 JG (or any jet drive for that matter). This will give you the ability to trim your jet just as a sterndrive does. Yes it will help getting out of the hole a little better but it will ultimately help when you are under way and going across different water conditions. Give us a call and we can talk prices and you can also talk to a tech about helping with your cavitation problem. 707-585-0482
    Jun 2010
    I have a 12 je with no droop is it still possiable to hook this up how much with floor control
