Under 23' Classic Stevens Flat Bottom V Drive Project
Results 1 to 1 of 1
    Jan 2019
    Default Classic Stevens Flat Bottom V Drive Project
    1964 Stevens Flat Bottom (Project). The boat itself is in good condition. Only thing wrong is a bad stringer. That said I would probably replace both of them while it's apart. I have it stripped down and ready for stringer replacement and hardware reassembly. Comes with good trailer which I have partially disassembled to be repainted. Can easily be put in order to haul the boat from my place to yours.
    Title in hand. The hull identification number is #575. I've only heard of one other on the west coast which is lower. This boat is a truly a beautiful classic. Check out the pictures.
    Everything is there accept of the motor:
    • 10 Degree Hal-Craft V-Drive
    • Two 10 Gallon Gas Tanks
    • Stringer Rails
    • 3 Blade Brass Propeller
    • Drive Shaft
    • Drive Shaft Strut
    • Skaggs
    • Cavitation Plate, Linkage, And Assembly
    • "T" Handle Cavitation Plate Adjustment
    • Foot Throttle Assembly
    • Seats And V Drive Cover
    • Fuel Pump
    • Chrome Alternator
    • Steering Wheel and Assembly
    • Steering Rudder
    $1,000
ID:	1029559   Click image for larger version.
ID:	1029561   Click image for larger version.
ID:	1029563   Click image for larger version.
ID:	1029565   Click image for larger version.
