alky motor
Results 1 to 3 of 3
alky motor
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    Default alky motor
    what is the best oil to use when running alky
    Senior Member cheyenne580's Avatar
    I use Brad Penn 50w in my BBC 580ci blown and injected on alky. Or if you are planning to do a lot of oil changes then use VR1 50w Valvoline.
    Jim
    Apr 2009
    San Diego, CA
    Don't freak out when you see the milky oil. It's the norm as the the methanol washes past the rings. Just plan on changing it regularly. I'd go with what your engine builder recomends. We used to run Kendall 50 wt back in the day, but times have changed. I'm very happy with Royal Purple at this time.
