540 cu in w/pro charger want to change to roots
Results 1 to 3 of 3
    Member zx14's Avatar
    Apr 2010
    Default 540 cu in w/pro charger want to change to roots
    I have a 500efi built up to 540 with dart pro 1 heads blower pistons bigger injectors and a m1 pro charger at 8 lbs when I can get the belt tight enough. I want to go to a roots type blower.
    questions.
    i like the looks of a big belt 10 or 1271.
    a whippile is more efficient is the 500 efi stage 2 big enough?
    Is there really enough difference between the whipped and the standard roots typ if you go big?
    anybody try the rootz injection system?
    How much you think I can sell the pro charger for?
    All this is on my 2003 26 Daytona, runs over 100 any day with a 32p
    Thanks all
    Senior Member dankdave79's Avatar
    Sep 2010
    Rootz kit works great ! But as with any efi set up it's all in how it's tuned .
    Jan 2014
    Default roots
    I am using a roots with a/w intercooler and carbs but if I can help I will.
