Dana 18 running in reverse to power jet drive?
Results 1 to 3 of 3
    Jan 2014
    Default Dana 18 running in reverse to power jet drive?
    Hello Bob: new to this site> i have this obsession to build an amphibious vehicle. started on chassis and drive line. the uncertainty issue is that i have to connect a powerglide trans. to a dana 18 transfer case( standing on end& running in reverse) would it howl real bad? the idea is to shift from trans to jet drive. in high gear only on case. ( manual shift trans) hope photos come though. any ideas to insulate noise OR? thanks Rick
    Feb 2014
    A few things I see. 1. The 18 is splash lube, you will probably have oiling issues on the top bearings. 2. Your current configuration shows the trans on the rear output, a diff on the front output, and I assume you are running the jet on the input. This basically allows you all powered, or neutral.
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    D18 are cheap and worthless, run it and see if it eats bearings.
    I see another huge issue tho. A floating 2WD rig is NOT going to drive back out of the water. TRACTION is a big deal.
    You need to build a 4x4 and then look into an older NP200 out of an old M37 with tandem rear axles. You wil have a divorced case (bonus) and working HI and LOW (bonus) and TWO rear driveline outputs.
    Running the rear axle full time is not an issue, but turning a jet when dry is bad. You will need a driveline disconnect for the jet. The disconnect can be made out of junk with something like an axletube out of a ADD rig like an older jeep cherokee with a two piece axle that has a coupler to connect the two halves.
