spacing between prop shaft and v-drive out put shaft
Results 1 to 3 of 3
    Senior Member 69 wriedt devil's Avatar
    Aug 2011
    central Cali
    Default spacing between prop shaft and v-drive out put shaft
    Hi just replaced seals and strut bushings. Shaft is back in and want the correct spacing between shafts. thx also i guess the spacing between the prop and strut. thx in advance!
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    Quote Originally Posted by 69 wriedt devil View Post
    There should be no spacing between the output shaft and prop shaft. The coupler should have equal amounts of each shaft inside and two shafts should be butted up against each other.
    There really shouldn't be a gap between the barrel of the prop and strut either. I'd say a 1/2 inch is acceptable depending on the power you have but would rather have about 1/8 of an inch or so. I can't get a prop puller on mine without loosening the coupler and sliding it back a lil.
    Aug 2011
    central Cali
    Perfect. Thx. Its a 427 with a 6-71 blower. Thx again
