cam help
Results 1 to 3 of 3
cam help
    Jul 2014
    Bakersfield
    Default cam help
    The picture attached is the cam card or specs on the Kim that I was sold for my 427 I am building for a flat bottom I hadn't paid attention up until 2 days ago As I am putting the bottom in together what my question is it is I see guys talking about 112 to 114 load center this list only as one hundred and ten does anybody have any input on this should I not run this cam or pros and cons to running a cam
    Member Waterslinger's Avatar
    Merritt Island FL
    Can not blow up the cam card to the point its readable. What is the grind number, comp is big on 110 CL. What is the set up boat and motor?
    Tri-Cities, TN
    How wet is the exhaust?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
