2000 454 mag , Holley carb backfires
Results 1 to 2 of 2
    May 2015
    Default 2000 454 mag , Holley carb backfires
    I have a 2000 454 mag in my 87 Baja 240 sport. I was running premium gas in it and it ran fine except at low rpm. I was told i should run 87-89 octane instead because it will burn better then the 92 premium. The problem is, once in a while when i shut it off, it back fires out of the Holley carb once before shutting off. Its more like a spit instead of a back fire. Could this be a timing issue or carb issue. Thanks, any help would be greatly appreciated. Dan
    SoCal
    Dan, check out HolleyTV.com. There are 5 pages of videos on Holley issues, setups, troubleshooting. You should be able to find an answer there. Otherwise call Holley's tech line. I spoke with them the other day while waiting for my new carb to show up and they are extremely helpful. Good luck. John
