bravo drive rotation
Results 1 to 2 of 2
    Sep 2014
    Default bravo drive rotation
    I have 1990 Baja 370es with twin stock Mercruiser 454/425hp and bravo one outdrive, 21 mirage plus propeller, top speed with good condition 61 to 63 mph at 4700 rpm, outdrive rotation (port cw) (starboard ccw) is the correct rotation? or if I should reverse the outdrive?
    thx
    Dan
    Member ezstriper's Avatar
    fredericksburg, va
    they are reversed with the shift cables, the drives are the same
