454/425hp carb misfire problem
Results 1 to 6 of 6
    Sep 2014
    Unhappy 454/425hp carb misfire problem
    have 1990 Baja 37' withtwin 454/425hp carbureted, one of this have misfire at high rpm 4200 and up, I installed a new ignition coil but I still have the same problem
    Thanks for your help
    Dan
    Sep 2009
    Walled Lake, Michigan
    Default misfire
    Did you look at your valve springs? May not necessarily be broken, but they could be weak due to age and fatigue. Just a thought.
    Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    Sep 2014
    the problem has to start when I was using the power trim high speed, I had a problem on groung of my battery, I repair this problem, but now I have the same problem without using the power trim at high speed, I thought that the ignition coil had been damaged because of my gound problem on the battery, I change it for a new coil without good result, I was not made to check my valve springs because I thought rather a electric problem, but if I can find no other solution I will check the valve springs but for that I will have to remove the engines!
    Jun 2010
    Just me but I think your cam is going bad
    rollin on the river DAVEO's Avatar
    Oakley, CA
    Change your distributer cap. I had the same issue changed plugs wires rotor and cap found 1 inch crack from over tightening.
    Alcohol free since 8/8/1993
    My life is just a dream....
    Aug 2016
    pull your distributor out push the shaft and gear up check for play or wear at top of shaft this can create a high speed miss
