Recommendation on outdrive upgrade
Results 1 to 3 of 3
    May 2016
    Default Recommendation on outdrive upgrade
    I have put a 300 "Tempest" Mercruiser SBC w/ a B&M 144 Supercharger, in my 1987 21ft chris craft scorpion 210 limited boat. And i might want to go to a SBC 400 or go ahead and put a BBC Mercruiser 502 "bulldog "in the boat. The outdrive is a Alpha 1 gen 1 drive and im sure with the "Tempest" i've reached the power limit on the drive. Any thoughts on going to a Bravo 1 vs TRS or something else
    Senior Member port austin pirate's Avatar
    Jul 2010
    Granite Bay Ca.
    Default drive change
    go with a bravo, youl have to baby it a bit, but if you do it will last. Trs includes a transmission and is extremely heavy en large. bravo xr or imco would be next step up, but unless you can get a good deal used lots of bucks, hope this helps
    May 2016
    Thank you it does
