302 swap.
Results 1 to 5 of 5
302 swap.
    Sep 2016
    Default 302 swap.
    Blew my 302 in my 19' chaparral. I have a crate motor that I am not using. Do I need to swap the cam? The research I have done seems to indicate that the cam in the crate motor and the cam that summit recommends operate at the same rpm range. The cam from by boat and the new one that is recommended both have the firing order of a 351.
    Just Me snoc653's Avatar
    Eastern Iowa
    Does your boat have a closed cooling system? Usually boats have extra clearance in the bores to allow for the cooler block temps that boats with open cooling systems have. A standard crate motor might be too tight to live very long in a boat. The pistons will expand and could score or stick in the bores as the block will stay cool. If you have a radiator in the boat, then go for it.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    This is absolutely wrong. Trainloads of 350 chevy engines dropped off at Mercruiser, and out the other door- a fully marinized Merc 260.
    I would think the same for Ford motors, too. Not huge HP in a 302.
    As long as the cam doesn't have too much duration for water cooled exhaust, go for it.
    But what do I know. Mine has a ditch pump.
    Dan'l
    "Never mind the mule, Just load the wagon"
    '76 Eliminator 21'
    Quote Originally Posted by Mash on It View Post
    Dan'l
    So you have not considered with the quantity that Mercruiser orders, they get theirs built to their own marine spec?
    Gale Banks just had 2000 or so diesel engines custom built to his spec for his military turbo diesel engines that he is supplying the government with.
    Willow Beach & BHC
    No, I had not considered that.
    Its a 302. At best (@1 hp/cu in) 302 hp. Probably less.
    I guess it wont work.
    Dan'l
    '76 Eliminator 21'
