How to Lower Compression?
Results 1 to 3 of 3
    Jul 2013
    Default How to Lower Compression?
    Hey guys/gals
    I have a 588 NA motor (Dart Big M tall deck, 4.56 bore) with AFR 335 heads that is at 700hp on the dyno, compression is 10.5 to 1. I would like to see the motor more around 800-850hp, so I figured best bet would be to put a Whipple 3.3 on her, but compression is obviously to high. So, what would be the best method to get it down and what would be the best number to get it down to? Motor only has a few hours on her so prefer not to do a total rebuild. Am I screwed? Your thoughts?
    Frank
    I know a thicker head gasket is a simple way to lower it, but I too would like to hear what the pro's think is the most acceptable way to do it.
    Quote Originally Posted by PORT View Post
    Hey guys/gals
    Frank
    I sent you a PM last week, since this column might not get looked at or answered the same as if you put it on the "dyno" section. Pro's are going to tell you what I did in the PM, you are going to need to change pistons to drop that much compression.
