SE Racing
Results 1 to 12 of 12
SE Racing
    Default SE Racing
    GOOD MORNING. Been kicking around the idea fo using one of my boats for SE racing. Anyone in this area doing it. I have a boat ready to go except for motor. Need to build a SE Spec SBC. Have a lot of the parts already. Anyone want to go play?
    Senior Member jody's Avatar
    Nov 2012
    nj
    Default Se 30
    Not sure where your located but I'm in NJ and plan to hit all east coast races and maybe a west coast run
    I am by Sacramento CA.
    Tower Park Resort, Lodi, CA
    I've been wanting to participate in the Parker Enduro and figured their Division 1 would be a fairly easy and relatively inexpensive (yeah right ) way to get involved. I think it's very similar to the SE class. Seems a guy willing to scour around for the right deals could put something together for $5-7k.
    What venues would hold races for the SE class that are near here? Is Ming/Bakersfield the closest?
    IDGAF acatitude's Avatar
    Discovery Bay/ Lake Havasu now
    Het Seth, not sure what SE class is but am down here in Parker now at bluewater watching the super stocks and stocks and cracker boxes circle race this weekend. Since im retiring at end of year I need a new hobby.
    26HOWARD CAT
    I think Ming, Elsinore, Long Beach and a few more that are fairly close. I am looking for the schedule now.
    Quote Originally Posted by acatitude View Post
    Congratulations Ken! A little jealous about not being in Parker right now, sounds like a good time.
    Here's the rules for SE Class
    Sportsman Entry (SE) Class Rules
    SE Class Rules Approved 20111206Approved: 6 Dec 2011
    Page 1 of 3
    RULE 55 – SPORTSMAN ENTRY (SE) CLASS
    SE (Sportsman Entry ) is an entry level class intended to promote a fun , affordable class with amaximum speed of 85 mph using only GM cast iron small block and cast iron heads derivedfrom passenger or truck model vehicles., and abiding by inboard runabout & safety rules
    55.1 General Rules55.1.1
    A prop shaft release is recommended but not required
    55.1.2
    Maximum speed of 85 mph is allowed.
    55.1.2.1
    Starts may be either clock start or flag start. For flag start laneselection shall be by draw.
    55.1.2.2
    A GPS may be run in a heat of racing to determine speeds thatmay require the use of a restrictor plate.
    55.1.2.3
    Because this is a speed limited class, there shall be nocompetition or kilo records kept.
    55.1.3
    Minimum length of an SE hull is 16 feet.
    55.1.4
    Minimum width of a SE hull is 72 inches.
    55.1.5
    Hulls under these minimums which competed in an older racing class areto be grandfathered. Contact the Class Chairman for confirmation.
    55.1.6
    Minimum, weight, including driver and safety equipment shall be 1850pounds weighed immediately after a heat of racing, after draining the hull ofwater.
    55.1.7
    If a hull with a safety capsule participates, it must start and race from theoutside.
    55.1.8
    SE boats are to run with only two bladed propellers.
    55.2 Hull Configuration55.2.1The
    hull must conform to the flatbottom hull requirements as specified inthe Technical Manual for the Inspection of Racing Runabouts.Non-current hullswhich do not conform to these specifications may be exempted by petition to theClass Chairman.
    55.3 Engine55.3.1 General Notes55.3.1.1
    No titanium engine parts are allowed.
    55.3.2 Block Assembly.
    Any GM cast iron small block engine block designed forgeneral automotive or truck use may be used.
    55.3.3 Bore and Stroke..
    Maximum Bore x Stroke is 4.065” x 3.500”
    55.3.4 Crankshaft.
    Any aftermarket crankshaft may be used.
    55.3.5 Pistons.55.3.5.1
    Only flat top pistons with valve relief(s) are permitted.
    55.3.5.2
    Any aftermarket pistons may be used..
    55.3.6 Connecting Rods.
    Any aftermarket steel connecting rods may be used.
    55.3.7 Cylinder Heads.55.3.7.1
    Only stock GM cylinder heads with in-line valves.may be used.
    55.3.7.2
    No porting, polishing, or grinding is permitted in ports orcombustion chambers.
    55.3.7.3
    Heads shall have a maximum intake runner volume of 170 cc
    Page 2 of 3
    55.3.7.4
    Combustion chamber volume using compressed gaskets anddeck height shall meet the following values:Compressed Gasket and DeckHeight in Inches
    Minimum Volume in cc’s0.085”
    64 cc
    0.070”
    68 cc
    0.055”
    72 cc
    0.040”
    76 cc
    55.3.8 Camshaft and Valve Train55.3.8.1 Camshafts.55.3.8.1.1
    Only flat tappet camshaft and lifters may be used.
    55.3.8.1.2
    Either hydraulic or mechanical lifters with a maximum
    diameter of 0.843” may be used.
    55.3.8.1.3
    Maximum lift, measured at the valve, shal not exceed
    0.450”.
    55.3.8.2 Timing Chain.
    Use of any chain set or gear drive of dual idlerdesign only is permitted.
    55.3.8.3 Valves.55.3.8.3.1
    All steel or stainless steel valves with a miniimum valve
    stem diameter of 11/32”
    with a minimum 0.340/0.341 stem diameter
    55.3.8.3.2
    Maximum diameter of intake valve is 1.945”
    55.3.8.3.3
    Maximum diameter of exhaust valve is 1.505”
    55.3.8.4 Valve Springs.
    Valve springs shall have a maximum diameter of1.260".
    55.3.8.5 Rocker Arms.55.3.8.5.1
    Roller type rocker arms with a maximum ratio of 1.52 may beused.
    55.3.8.5.2
    Studs and/or guide plates with 5/16” pushrods may be used.
    55.3.8.6 Adjusting Nut..
    Any adjusting nut may be used.
    55.3.9 Intake System55.3.9.1 Intake Manifold.55.3.9.1.1
    Any production style as cast/as produced iron or aluminumintake manifold may be used
    55.3.9.1.2
    Sheetmetal or tunnel ram style intake manifolds are expresslyprohibited.
    55.3.9.2 Other Intake System55.3.9.2.1
    A carburetor spacer is required; it shall have a minimumthickness of 0.500" (including gaskets) and a maximum thickness of 2.25"(including gaskets. The spacer may be wedge shaped, if desired,providing it fits within the above envelope. A restrictor plate, if required,shall be in addition to this thickness.
    55.3.9.2.2
    The intake manifold may be matched or blended to thecarburetor spacer.
    Page 3 of 3
    55.3.9.2.3
    Use of any intake scoop, velocity stack, and/or air cleaner ispermitted.
    55.3.10 Fuel System55.3.10.1 Carburetor55.3.10.1.1
    Carburetor is to be a Holley #4776. Only the followingdimensions are to be inspected.
    55.3.10.1.2
    Maximum venturi diameters:
    Primary/Secondary = 1.265”/1.3275”
    55.3.10.1.3
    Maximum throttle plate bore is 1.5675”
    55.3.10.2 Fuel and Fuel System55.3.10.2.1
    Any pump gas may be used, including E85.See Rule 40.18.02
    55.3.10.2.2
    Any fuel pump is permitted
    55.3.11 Ignition.55.3.11.1Ignition
    system may be either points-type system or HEI system
    55.3.11.2
    Electronic ignition systems are not permitted. Pertronixdistributor points conversions may be used.
    55.3.11.3
    Any plug wires may be used.
    55.3.11.4
    Firing order is to be 18436572
    55.3.12 Exhaust.55.3.12.1
    Any manifold or steel header with a collecter of the standardstraight style may be used 55.3.12.2 No multi-step or 180 degree systemsmay be used
    55.3.13 Lubrication System.55.3.13.1
    A wet sump system with the oil pump mounted in the stocklocation is required.
    55.3.13.2
    Any oil pan is permitted
    55.3.13.3
    Accusump systems are permitted
    55.3.14 Other Specifications55.3.14.1.
    Any gasket set may be used.
    55.3.14.2
    Vacuum pumps are not allowed.
    55.3.14.3
    Use of a heavy duty/SFI flexplate or aluminum flywheel isrecommended.
    55.4 Class Chairman.55.4.1
    The Class Chairman is Paul Grichar.. He may be contacted at
    [email protected].
    55.4.2
    Vice Chair is Dave Weber who may be contacted at
    [email protected]
    55.4.3
    The class shall be directed by the Class Chairman and Vice-Chairman through 31 October 2016.
    55.4.4
    Rule change proposals for this class shall be submitted to theClass Chairman.
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Rick I thought you wanted a bigger boat?
    I thought I read you got a SS style boat? you should run the 95 class?
    Quote Originally Posted by Hullshot View Post
    I have 5 boats. Need one? I have a Nordic Flat that might be a good one for the 95 class. I also have the Jones. It is 16 1/2. The Old Carloson is a 18. It might be good for the 95 as well. The new Hondo is a runner bottom. Was going to use that for a Hot Rod. Got a 557 for it. It needs lots of parts. Hull with strut and log and plates is all it has. For the SE class all I need to do is build a SBC. They are almost a stock motor. That would be the quickest way and cheapest way to go racing. Remember I have never ran in circles before. Thought this 85 mph thing would get my feet wet. I could step up later to the 95 or PS or SS later if I really like it.
    Did I mention that I might wait untill Rainbow Rankin moves up before I go SS.
    It's the Gnats fault.
    Dicovery Bay
    It's the Knats fault.
    I will be in a wheel chair before he and Tony give it up..LOL.. We aint got a chance out there..
    wouldnt matter anyways I would be battling for last place.
    Doubt that. I can take that one.
