My Junk
Results 1 to 14 of 33
My Junk
    Tower Park Resort, Lodi, CA
    Default My Junk
    My initial problem was water in the oil. After doing a bit research I decided to throw her back together, sealing everything just right. Soooo,
    I have a running boat. I'll find out this weekend if I'm still getting water in the oil.
    Just an update.
    -Seth-
    Cantard 71hallett's Avatar
    snow bank
    Nice. Hope it works out for you.
    NOSTALGIC V-DRIVES DIMARCO21's Avatar
    Nor Cal
    Thumbs up
    Good job Seth!!! I'm digging the clear distributer cap.
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    SETH the water issue ,where is your water coming in at your headers ,if it's to low on the pipes your probably getting a little forced in the heads from there ! seen this alot on flats with over the transom ,put a valve in line so you can slow the pressure ! good luck thanks again yuou tube master !!!!TUNNELT
    FINAL TOUCH DETAILING
    Senior Member Cat Sass's Avatar
    Shingle Springs, CA
    Right on Seth! Glad to see it coming together.
    a.k.a. "Mean Pair" Nice Pair's Avatar
    I want out of Kalifornia
    Thumbs up
    See Seth run, See Seth play.. Go Seth Go. Congrats & good luck, keep us posted.
    BIGJOEDUCKSLAYER BIGJOEDUCKSLAYER's Avatar
    SACRAMENTO
    Looks like time to go for a ride in v-drive flattie
    BIG JOE SSMF When it rains, we pour
    Trying to Re-Member Waffleman's Avatar
    Northern Taxifornia
    Thumbs up Sounds good Seth!
    Good luck w/water test
    "I'd rather be lucky than good"
    Quote Originally Posted by TUNNEL T View Post
    Thats what I heard too. So I'll be running them dry until I get a Bassett valve, which wasn't on the engine before. So, I'm crossing my fingers that it solves the problem.
    Big Joe... Any time buddy. Let's just hope it works correctly.
    Everyone else... Thanks for the kind words and encouragement!
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    Just an update.
    -Seth-
    Thats bitchin Seth, good luck this weekend. I know we are all rooting for you bro.
    What happens on the Delta stays on the Delta
    Discovery Bay Ca.
    Well, whats the verdict?
    Shingle Springs, CA
    were all waiting...................
    Senior Member Hullshot's Avatar
    Dicovery Bay
    comon Seth, We all hope it went well. WELL???? I have never seen a clear cap on a motor while running, how tripy Let us know. We are going out again today.
