Franks Tract gotcha's?
Results 1 to 10 of 10
    a.k.a. Jon shortbus's Avatar
    May 2013
    Discovery Bay
    Default Franks Tract gotcha's?
    Looking at a nautical chart, the Franks Tract "island" is mostly 5-7 feet deep. I've always stayed on the east side in the Old River channel, or right along Bethel. The charted depth should mean the middle is full of Egeria (that nasty water weed). The NW "corner" is indicated 1-3 feet deep. There have been times when I've wanted to cut across but always go around as I'm not sure what to expect (weeds or depth/snags). All those flooded "islands" scare the crap out of me.
    So, you longtime south Delta peeps, is Franks Tract one of those "need to follow someone that knows" kind of deals? .... or just GO AROUND?!
    yellow Stoker 204 + 300hp + disability = shortbus
    ...help find a cure, support http://www.fshsociety.org
    NOSTALGIC V-DRIVES DIMARCO21's Avatar
    Nor Cal
    Been across it many time's during high tide, there are only certain places to cross. I'm sure NP or Mr. Waffle know them in their sleep.
    Going around is by far the cheapest for prop repair.
    Senior Member h2oracer's Avatar
    Franks tract, last year at high tide.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    If you head into FT from Old River side off of the SJR then take a heading on the tallest trees in the distance, theres like 3-4 Poplar trees on the shore that are taller then all the rest. Head straight for those trees and stay on track until you get to the other side and then turn left and you'll see the Rusty Porthole Windsock. Thats the way I do it every time and have never had a problem with depth, usually stays about 6-8 ft all the way.
    At WOT theres not much boat in the water.... if you chug along and drag yer ass your gonna hit something.... someday!
    Diesel Pimp WINspeed's Avatar
    Aug 2009
    East Bay, ca
    Just keep it aired out and you wont hit anything.
    Senior Member HighVoltage329's Avatar
    San Jose, Ca.
    Nor-Cal has held ski races out there for years without problems. Lots of boats pulling skiers that covers most of the open area. NE corner is more shallow.
    May 2013
    Discovery Bay
    Default lol
    Quote Originally Posted by WINspeed View Post
    Now THAT's comforting. I guess with the motor jacked up and doing 80 it's almost a fan boat,... still, there's just something about not knowing what lurks beneath.
    Senior Member lake p.a.l.'s Avatar
    Benicia, CA
    still, there's just something about not knowing what lurks beneath. [/QUOTE]
    I will make sure i go around Franks once my pile gets here in another month. I'd rather spend the extra $$ on fuel instead of prop/drive repairs and whatever else it would take out, call me whatever you want.
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Quote Originally Posted by shortbus View Post
    Add a Go Pro camera to the front of your boat and WIFI link to the Iphone on-board and you can watch...
    "WHAT LURKS BELOW THE DELTA"
    Wow now that sounds like a great new cable TV show for the Discovery Channel!!!!!
    Member DiscoDCB's Avatar
    Jul 2010
    Pleasanton, CA
    Default Watch out for the waterfowl !!!
    Quote Originally Posted by ptc View Post
    Hitting the Ducks on last years Hookie Day was quite exciting and bloody !!!!!
    2009 DCB f29 w/ Dual 625HP Ilmor V-10's towed by a 2012 Chevy 2500 Crew Cab ..... aka The Tow Package !!!
