Final Engine Build Plan/Schedule
Results 1 to 14 of 17
    Default Final Engine Build Plan/Schedule
    OK so we've come up with a build plan.
    Block was not align honed for use with main studs previously, which caused badly uneven bearing wear. This had nothing to do with why the valve and cam broke, but a definite problem that needs to be corrected nonetheless. Block will be getting align hone for studs as part of the machining process.
    0.060" overbore, making the motor a 468.
    Going 9.5:1 compression (like before). Stock GM crank and rods. We'll be using a race bearing this time (originally used Clevite77 bearings) upon recommendation from the machinist.
    Pistons are made by Probe Industries. Supposed to be stronger than most available and they're made in California.
    Cam will be SLIGHTLY hotter than what I had before. The last cam I had was a single pattern cam...going dual pattern this time. Here are the cam specs for the old and new cam:
    Old Cam: Isky 280H Mega
    280* seat-seat/232*@0.050"
    0.549" lift
    110 LSA
    110 intake centerline (installed at 106*)
    60* seat-seat overlap/12* 0.050" overlap
    New Cam: Comp Cams XM278H
    Intake Lift: 0.564"
    Exhaust Lift: 0.566"
    278* intake duration/292* exhaust duration @ 0.006"
    234* intake duration/244* exhaust duration @ 0.050"
    112 LSA
    61* overlap @ 0.006"
    Both heads are getting replaced. GM OEM casting 353049 large oval port with larger valves (2.190" intake/1.880" exhaust). 1-piece Ferrea stainless valves. Hardened exhaust seats.
    Same carb and intake as before...Holley Marine 750DP and Edelbrock RPM Air Gap manifold.
    With any luck I'll end up with the same top RPM as I had before. I'm only changing the shaft seal in the pump but all the internals...impeller cut/clearances will remain the same until I know where I'm at with the new motor.
    More details to follow as the build progresses. Due to financial limitations it's lookin' like I won't be able to start reassembly until late January.
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    tis da seasons, atleast you can get the ball rollin soon, hey will your 468 run and sound like this one..............
    I call it the brain tube, I've been telling her the more time she spends on it, the smarter it's going to make her.
    Trying to Re-Member Waffleman's Avatar
    Northern Taxifornia
    Default Get Some!!!
    Quote Originally Posted by 707DOG View Post
    Hey wanna go for a ride..........sure thanks
    "I'd rather be lucky than good"
    vallejo,cali
    Quote Originally Posted by Waffleman View Post
    yeah that ride can cause some serious blood flow
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Why don't you bump the compression up to around 10:1 ?
    What impellor are you running ? a/b ?
    [/SIGPIC]
    Quote Originally Posted by Lucky View Post
    Tryin' to stay pump gas friendly.
    Running an American Turbine AB impeller but once I get a different baseline with the new mill depending on what RPM I get out of that I'll probably switch over to an Agressor B.
    Ukiah,Ca
    YOu will with 10.1 to 10.25 - watch your timming What rpm where you turning with the last cam ? pump combo ?
    [/SIGPIC]
    About 5400-5500.
    Ukiah,Ca
    sweet
    About 5400-5500.
    [/SIGPIC]
    sweet
    That's also with a White Lightning loader. Without a shoe or rideplate she topped out at 79mph.
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    Hey john, had the cam and lifters in stock i'll put em aside for ya. Should be a strong motor you hopefully won't have to tear apart for awhile.
    CP Performance
    www.cpperformance.com
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    Senior Member bad news travels fast's Avatar
    San Jose
    All I can say about that video is one end of Don Pedro to the other in 7 minutes. I like it. My personal record is 11 but who knows with the new boat.
    Tommy
    Tony...don't think I'll be spinning that kinda Rs unless the pump unloads
    That thing does sound badass though
    Quote Originally Posted by CP Performance View Post
    Thanks Brian...that'll work.
