Delta water level
Results 1 to 9 of 9
Delta water level
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    Default Delta water level
    What's up w/ the low water level on the delta? Is it because
    of the locks being closed? I'm glad I didn't have the jet out,
    the crap was at the surface floating everywhere. My friends
    who used to live on the delta said they haven't seen it that
    low before also. We had to make a trip to Paradise to ck out
    the house boats for the 4th of July weekend, I'm looking
    forward to that!!
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    water level in the delta depends on the tide in the bay!!!!TUNNEL T
    FINAL TOUCH DETAILING
    The level is a bit low. I took the Formula out last week and could have sworn I ran a ground near boat docks on the right as you idle towards Orwood Marina. I did not have my depth finder hooked up when it happened but I'm sure the water level was very low 'cause I churned up a lot of mud and weeds. I had to trim my outdrives up to make sure not to damage anything. I will have to refinish my outdrives and re-polish my cleavers before the next outing.... Oh well, shit happens! Just need to make sure to hook up the depth finder next time.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by konajet74 View Post
    forward to that!!
    there was a -1' tide yesterday and along with the locks being closed, it's probably what you observed. When we had our place on the Delta years ago, we saw quite a few pretty darn low water levels.
    There's also going to be minus tides for the next few days and then a -1.9' tide on the 25th of this month.....that'll be the one to see. Frank's Tract might look like a big mud puddle.
    AARP Member Rocket-J's Avatar
    Gilroy, Ca.
    Default Full Moon
    Kind of goes with the full moon, doesn't it? That's my tide chart.
    Member "TAKIN ADVANTAGE"'s Avatar
    Discovery Bay
    Wish i would have taken a pic of the rear of my dock out of the water last week.Stabilizer hiting the bottom and picked the back of the dock right out of the water.Didn't like that.long timers said they never seen that before.
    Cas
    Cas is offline
    Quote Originally Posted by Rocket-J View Post
    well yea, the moon has the effect but it's not just the full moon. Here's the tide table for the month of May 2009
    # High Low High Low
    1 Fri 0446 5.3 1145 -0.5 1918 4.8
    # Low High Low High
    2 Sat 0029 2.5 0605 4.9 1247 -0.2 2007 5.1
    3 Sun 0144 1.9 0727 4.6 1344 0.2 2050 5.4
    4 Mon 0246 1.2 0845 4.5 1435 0.6 2128 5.7
    5 Tue 0339 0.5 0956 4.4 1521 1.0 2204 5.9
    6 Wed 0426 -0.1 1059 4.5 1604 1.5 2237 6.0
    7 Thu 0509 -0.5 1156 4.5 1646 1.9 2308 6.1
    8 Fri 0548 -0.8 1249 4.5 1726 2.2 2339 6.0
    9 Sat 0625 -1.0 1338 4.4 1806 2.5
    # High Low High Low
    10 Sun 0011 5.9 0702 -1.0 1426 4.4 1846 2.8
    11 Mon 0044 5.7 0740 -0.9 1513 4.3 1928 3.0
    12 Tue 0120 5.5 0820 -0.7 1601 4.2 2014 3.1
    13 Wed 0159 5.3 0902 -0.5 1650 4.2 2108 3.2
    14 Thu 0243 5.0 0948 -0.2 1738 4.2 2215 3.2
    15 Fri 0334 4.7 1037 0.1 1824 4.3 2330 3.0
    16 Sat 0433 4.3 1127 0.3 1903 4.4
    # Low High Low High
    17 Sun 0041 2.7 0541 4.0 1217 0.6 1938 4.7
    18 Mon 0140 2.2 0658 3.8 1305 0.9 2010 5.0
    19 Tue 0230 1.5 0817 3.8 1352 1.2 2041 5.3
    20 Wed 0314 0.8 0931 3.8 1437 1.6 2114 5.6
    21 Thu 0355 0.1 1037 4.0 1522 1.9 2148 6.0
    22 Fri 0436 -0.6 1136 4.2 1606 2.2 2226 6.3
    23 Sat 0519 -1.2 1231 4.4 1652 2.4 2306 6.5
    24 Sun 0603 -1.7 1324 4.5 1739 2.6 2351 6.7
    25 Mon 0649 -1.9 1416 4.6 1829 2.7
    # High Low High Low
    26 Tue 0038 6.6 0738 -1.9 1508 4.7 1925 2.8
    27 Wed 0130 6.5 0829 -1.7 1600 4.8 2028 2.8
    28 Thu 0226 6.1 0922 -1.4 1652 4.9 2140 2.7
    29 Fri 0327 5.6 1016 -0.9 1743 5.1 2259 2.4
    30 Sat 0435 5.0 1111 -0.3 1832 5.3
    Cas
    Cas is offline
    here's the website, probably much easier to read than the cut and paste
    http://wolfweb.unr.edu/homepage/edc/...sfgg_fr09.html
    IDGAF acatitude's Avatar
    Discovery Bay/ Lake Havasu now
    water level up on the sac river. Its high enough I can spin my 40 ftr around instead of backing out...
    26HOWARD CAT
