time to change your oils
Results 1 to 14 of 26
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    Default time to change your oils
    ok fellas it's time for all of you to change gear oils and motor oils today!!!!! and since were on the topic you should really use a very good synthetic oil like AMSOILl in your pride and joys !!!!!if you don't have a catalog i can get you one !!!!TUNNEL T
    p.s. drew wheres your paperwork!!!!!
    FINAL TOUCH DETAILING
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    whats the differents between the mec synthtic oil and this stuff?? im having drew take care of my service really soon, so with my boat being non-high performance does it really make a difference????...ant
    disovery bay
    Default oil
    ant ,im not sure what mec synthetic is ,but i think you might be askin about merc synthetic ,with the amsoil you can actually go longer on your drain intervals . you can go to there web site for more in depth info ,drain intervals high temp comparisions ,cold temp comp. ,and the huge variety of oils for everthing that we all drive !!! TUNNELT
    vallejo,cali
    Quote Originally Posted by TUNNEL T View Post
    shit where was this stuff when i was single
    yeah i ment the merc oil !! it's what came in our boat so i kinda stuck with what they recomended, ill ask drew if ill it will help me out at all with going over to a different oil...
    Senior Member Cat Sass's Avatar
    Shingle Springs, CA
    I'll get some oil from you if you can hook me up with the girls in your avatar
    Does amsoil have an oil like the redline shockproof gear oil?
    disovery bay
    Quote Originally Posted by Cat Sass View Post
    yes they do have a shockproof oil! TUNNELT
    Member Den Isle's Avatar
    Amsoil is also making a marine grade synthetic which has a better water contamination stability.
    Any of the Amsoil products are excellent, I've been using their stuff since the early 80's and have always been pleased with the results.
    DSI Dan got an extra 200-300 RPM's when I switched him over.
    Going in...and we're going in deep.
    disovery bay
    Quote Originally Posted by Den Isle View Post
    thanks chris for the extra sales pitch ,i really think dan just grew a set and found the up buttonon his trim!!!!so far ive been pleased with it!!!! TUNNEL T
    Want to see my member? DsiDan's Avatar
    Morada, CA
    !%@#$ Racer52's Avatar
    Stockton, CA
    it was the up button
    racer
    Reduce drag, go faster
    I doubt there was sack involved
    disovery bay
    Quote Originally Posted by Racer52 View Post
    racer
    see proof at hand!!!! TUNNELT
    Northern CA DCB Sales Boatmaster's Avatar
    Discovery Bay, CA
    We didn't need to know about his hand gaining RPM!
    Stockton, CA
    maybe it should be verified at the next run. Dano should put her to the test.
    Racer
