want to borrow a prop for Cat Attack
Results 1 to 12 of 12
    !%@#$ Racer52's Avatar
    Stockton, CA
    Default want to borrow a prop for Cat Attack
    if anyone has a 30p or 32p bravo they are not using bring it up. I would like to switch props and see if the new motor has longer legs
    Boat seams to run the same rpms with all the props I have tried. just never put a big wheel on it yet.
    If not, it was worth a shot out to me fellow DLB'ers.
    Racer52
    AARP Member Rocket-J's Avatar
    Gilroy, Ca.
    Wink I have one.
    Hi Troy.
    The only one I have is on the boat. I am not bringing the boat but will need it back asap. If something happens to it, I still need one asap. It is a stock Bravo 30. Not to put the pressure on you. My vacation is in two weeks. Al
    Stockton, CA
    Hey Al bring that sucker up. If we find time I may switch it out for a run or two? Just want to see what prop I should be buying for a second prop.
    Sold my smaller 26p since I knew I wasnt going backwards and the boat planes perfect even with 6 people loaded up with the 28p I have on it now.
    I would really like to try a labbed 32 also to see what it would do.
    Racer
    Gilroy, Ca.
    Exclamation
    I have a lab 32 but it has been repaired. It has been on a couple of big HP boats and I don't trust it much. Okay for my little Putt-Putt.
    I have a labbed 30p and a standard 28.. I will be bringin both props with me....
    Stockton, CA
    Quote Originally Posted by t-bag'n View Post
    Sweet. See you Friday
    Stockton, CA
    Quote Originally Posted by Rocket-J View Post
    Yep, one thing that would suck would be to break a blade on a borrowed prop.
    I never have broke a blade but Don sure broke a few, so has Drew.
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    Quote Originally Posted by Racer52 View Post
    yea but those guys are gay TUNNEL T
    FINAL TOUCH DETAILING
    Senior Member Hullshot's Avatar
    Dicovery Bay
    So how did it run with a 30-32 prop. I have 32 and 34 you could try.
    Stockton, CA
    that would have been too much work to change a prop.
    So it ran like it always does. (not too bad)
    Maybe someday on a delta trip we can switch a prop out.
    Racer
    Member Den Isle's Avatar
    Default Delta Trip??
    I resemble that... and have a dock.
    Hasta! Chris
    Going in...and we're going in deep.
    Stockton, CA
    catch you on the next delta cruise. Possibly Sunday.
    We will give you a call if it works out that way.
