Need a prop B4 Hookey Day!
Results 1 to 14 of 24
    Senior Member Cat Sass's Avatar
    Shingle Springs, CA
    Default Need a prop B4 Hookey Day!
    Hey guys I found a crack in my prop. Bummer! Its a 30 Labbed one. Anyone have a spare they wanna sell? 28-30ish pitch.........
    Can a cracked one be fixed?
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    Quote Originally Posted by Cat Sass View Post
    yes it can depending on how bad !!!send to phils propeller in lakehead .send now you should still get back in time!!!TUNNEL T
    FINAL TOUCH DETAILING
    IDGAF acatitude's Avatar
    Discovery Bay/ Lake Havasu now
    Hate to disagree with T, but runnin100 with a repaired prop that was cracked is not a good idea.
    That labbed prop is already cut real thin and trying to repair it?? I don't think I would trust it ever being fully repaired
    26HOWARD CAT
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    I call it the brain tube, I've been telling her the more time she spends on it, the smarter it's going to make her.
    Senior Member stoker2001's Avatar
    Folsom,Ca
    Quote Originally Posted by acatitude View Post
    good points
    I really hate the idea of welded props on my little pisspot,cause if it fails at 115+ yyou probably are getting wet
    with that being said on a 25' daytona it would probably just vibrate and worst case take out your cavatation plate when it exits
    good prop welders have been succesful at it
    Tru Pitch Props over off of Auburn Blvd near Rex Hutchinson might do it if you sign a waiver
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
    Kevin, I took my cracked lab to him to look at and he said he wouldn't even attempt it. Mine may have been worse then Todd's, but he even told me once they are cracked, they are more suseptable(sp) to coming apart again at high speeds. Last time I threw a blade my howard shook so violently I was afraid the whole transom was going to fall off.
    26HOWARD CAT
    Discovery Bay, CA
    Just weld it and run it! Unless it's an ultra-thin, labbed prop, then you may be wasting your time because it will probably not last long at all. Don't worry about the danger factor though, I've thrown blades and skegs off of all types of tunnels and cats ranging from 18' to 36' and never had anything bad happen. Like Kevin said, it will just vibrate if it throws a blade. You will want to carry a spare and also look into buying a new prop though, because once they've cracked and are welded, they are sure to crack again - and not necessarily the repaired blade. For that crack to appear in the first place means that the blades are fatigued and nearing the end of their life cycle. I cracked two blades on my last ultra-thin Lightning ET and caught them before they let go. I did not weld that prop though because I was told by the builder (Brett Anderson) not to. ALWAYS check your props for cracks before you run your boat.
    Northern CA DCB Sales Boatmaster's Avatar
    Discovery Bay, CA
    The big question here is, when was the last time your Howard ran 100mph Ken?
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    Quote Originally Posted by Boatmaster View Post
    Ouch
    What happens on the Delta stays on the Delta
    vallejo,cali
    Quote Originally Posted by Deltarat View Post
    Ouch
    x2
    Ouch, That was meant for cat sass who runs 100 all the time. Even at WOT in the Howard at 76.9 it shook like hell..
    I'm trying to rememer Drew, it was either when Grads bet me a hundy he could beat me ..... lol. Or maybe it was 3 years ago , the last time you attended a hooky day. lol
    26HOWARD CAT
    Discovery Bay, CA
    I'll be there this year in Old Yellow, we can figure it out then.
    Awesome, I'm thinking you buy me 1 or 3 brews and my mind will wake up
    26HOWARD CAT
    Senior Member Hullshot's Avatar
    Dicovery Bay
    sounds like a car boat vs. a whaker boat challenge to me
