Need quick help guys...............
Results 1 to 14 of 30
    Senior Member Aqua Boogie1's Avatar
    Default Need quick help guys...............
    I've talked to Dave and emailed Don(Hulshot). Dave gave me some advice and haven't got ahold Don, but here's my ?. How can I look at a lower end and tell if its shot or some what in good shape??? Its an 89 Sleekcraft Enforcer, 454 and bravo1 drive. Boat and motor has 120hrs original.
    Doug
    'Love is what's in the room with you at Christmas if you stop opening presents and listen.'
    Bobby - age 7 (Wow!)
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Doug,
    Are you shopping for a boat? Tire kicking?
    At the Seller's place, remove the drain plug. Allow a little oil to drain onto a paper towel.
    Now smell the oil, roll the oil between thumb and middle finger. Look at the magnet on the plug. Any metal?
    Results of tests...
    Oil smells burnt, acrid. Over heated, contaminated with water, too much time between oil changes.
    Oil is grtty. Metal transfer from gears, bearings and races.
    Metal on magnet. See above.
    Loose, the Dogs of War!
    Northern CA DCB Sales Boatmaster's Avatar
    Discovery Bay, CA
    Quote Originally Posted by Schi-502 View Post
    Doug,
    Results of tests...
    Sounds right to me. Also check for water in the lube.
    Thanks alot guys. Actually picking it up tommorrow. Just wanna check a few things, maybe I can work down the price if there some issues.
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    These guys are right on the info. if your serious take a new oil filter with you and change it out with the old one. cut the old one open and see whats in it. hopefully it will have clean oil and no metallic flakes or signs of moisture. if it has a foot then check the drive fluid for water and make sure its full of oil to the proper level. good luck
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    Quote Originally Posted by Aqua Boogie1 View Post
    Doug
    post a picture of that sucker i looked at a sleekcraft before i picked up the carrera, diffinatly have someone go over the drive and give it a once over!
    I call it the brain tube, I've been telling her the more time she spends on it, the smarter it's going to make her.
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Sorry Doug, I have been real busy the last 2 weeks. I sent you a PM.
    1989 Sleekcraft Enforcer 23.6ft 7.4/ Bravo One 115.9 original hrs.
    Blow a tire on the way and home and here I was waiting for AAA. Changed the tire but the spare had no air in it. So there goes an hour....................
    AB1,
    Where's home?
    Nice boat!
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    Congrats guys, I am stoked for you.
    What happens on the Delta stays on the Delta
    vallejo,cali
    hell that will do the job, she looks pretty nice now i got someone to cruise with sux about the blow out a good time to upgrade the tires and rims
    Quote Originally Posted by 707DOG View Post
    That's how I feel about Danny's sled. As long as one of us knows where the next stop is, we'll get there together.
    Thumbs up
    I said "sled" not slug!
