CMI Header Problems @ Offshoe Only
Results 1 to 3 of 3
    Member Rocker Down's Avatar
    Folsom Ca.
    Default CMI Header Problems @ Offshoe Only
    "WoW" Had no idea 525 CMI Headers were this Bad. Check out the response I got on Offshore Only. Forums/General Boating Discussion/CMI Exhaust Headers ( Warning ) 1,467 Views, & 44 Replies. Replacement Cost from Mercuey Racing now $8,800.00 + Tax per set. Cost two rebuild Two 825's Mercury Racing Engines damaged from the CMI Headers Buying used CMI Headers, is just buying someone else's problem, so they can buy new.
    Rocker Down
    Trying to Re-Member Waffleman's Avatar
    Northern Taxifornia
    Unhappy Sorry to hear Roy
    I'm thinking Class Action here There is no way they should get away with no participation in fixing this problem!
    "I'd rather be lucky than good"
    the silver bullet! TUNNEL T's Avatar
    disovery bay
    i say b.s. i bet if you throw a threat about a lawsuit you'll get a little rise outa them !!!TUNNEL T
    FINAL TOUCH DETAILING
