Two cold nights comin..............So,
Results 1 to 8 of 8
    Senior Member Aqua Boogie1's Avatar
    Default Two cold nights comin..............So,
    Should I be worried about my engine block for the next two night or should it be ok???? No water in or running out of drive. So should be empty. Asking because my boat is stored outdoors.
    'Love is what's in the room with you at Christmas if you stop opening presents and listen.'
    Bobby - age 7 (Wow!)
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    Id pump some anti freeze threw it - Water still accumlates right under the freeze plugs - it doens't all come out
    [/SIGPIC]
    Concord, CA
    Default winterize
    Well, my block already has a hole in it, but all my toys get parked in our wine warehouse were its temp controlled. Nice and comfy for the winter.
    Jerry
    Quote Originally Posted by Homez View Post
    As far as winterizing an outdrive ??
    Your drive will still have water in it. The waterpump in most is in the top of the lower unit. I have seen them freeze and crack the upper housing close to the Gimbel. If you can run it on the hose and shut it off. Then put the hose in a bucket of anti-freeze higher then the motor and run it till anti-freeze come out and is in the whole system. I usually run abought 6 gallons total. That is 3 gallons mixed 50/50. Good luck. Some of us will need it.
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Boat is covered, put a drop light under the bow and one under the engine hatch, put the batteries on charge. The jet doesn't need anything.
    AB1, lower the drive to remove water trapped in the exhaust area of the bearing carrier.
ID:	89805   Click image for larger version.
ID:	89806   Click image for larger version.
    Loose, the Dogs of War!
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    Wrap that bad boy in a blankie and be done with it already
    What happens on the Delta stays on the Delta
    pay me or pay me no mind 707DOG's Avatar
    vallejo,cali
    Quote Originally Posted by Deltarat View Post
    yep got 2 moving blankets over mine plus its in a inclosed car port
    I call it the brain tube, I've been telling her the more time she spends on it, the smarter it's going to make her.
