old fuel... new fuel mix??
Results 1 to 14 of 15
    !%@#$ Racer52's Avatar
    Stockton, CA
    Default old fuel... new fuel mix??
    I have about 10 gallons of pump gas from when the boat broke 14months ago
    left in one tank.
    Do you think mixing with new and octane boost would be ok?
    Or should I add 100octane to it 50-50
    Or drain and start fresh???
    It would not take long to cruise that fuel out during the break in outting with no hard loads or big boost.
    What do you think?
    Racer
    rollin on the river DAVEO's Avatar
    Oakley, CA
    Quote Originally Posted by Racer52 View Post
    left in one tank.
    What do you think?
    Racer
    Its been 14 mo. damn... Id drain and add neww. its only ten gal burn it in a weed wacker or lawn mower.
    Alcohol free since 8/8/1993
    My life is just a dream....
    IDGAF acatitude's Avatar
    Discovery Bay/ Lake Havasu now
    turn on your electric pump and pump it out and into your truck.
    26HOWARD CAT
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Troy sealed tank or vented? Makes a difference. sealed tank run it with some fresh stuff on top of it. Old stale fuel just add higher octane to it and burn it. Did it varnish up? Is your boat up and runing?? If so good to hear.
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    Between your 10 gallons and my 60 gallons we have 70 gallons of shit
    Drain, replace and dont look back.
    What happens on the Delta stays on the Delta
    Hell Terry sell that 60 gallons back to the gas station you will make money on it, lol.
    Gas is the only thing I buy that goes up the next day, wish I could pick stocks like that
    26HOWARD CAT
    Member Den Isle's Avatar
    Put your yamika away and put some good gas in it
    Going in...and we're going in deep.
    Dicovery Bay
    I got some 100ll that I will sell to you?????
    Senior Member obsessive compulsive's Avatar
    Livermore
    I towed you in, so you should give it to me.
    Senior Member DaveC's Avatar
    F.C, Norcal
    seriously... take a sample out and dump into a glass or jar and let it sit for a few minutes...
    any problems with the fuel will be very apparant... (it will separate)
    if its bad pump it all out and don't use it..
    been there done that...
    Car-boat motors
    Stockton, CA
    ya ya ya...
    fockers are all like that little bitch of a birdie on my shoulder.
    Filled the other tank and she's running. The other fuel did not look bad but did not smell like power making stuff. I will mix and add 108 booster.
    and will run with the fuel selector valve to both and run a full break in tank through it and after that it should be all good.
    Thanks for the reassurance that I'm a cheap ass.
    Racer
    Senior Member Washed Ashore's Avatar
    oakdale,ca
    ya ya ya...
    Racer
    Well,
    You got it half right
    Dicovery Bay
    Quote Originally Posted by Washed Ashore View Post
    Well,
    LMAO!
    Isn't that the same crap you blew your last motor on???
