88 omc outdrive
Results 1 to 6 of 6
88 omc outdrive
    Jun 2013
    milan new hampshire
    Default 88 omc outdrive
    trying to get outdrive off 88 bayliner cuddy cabin 5.7 with omc out drive, will not come out, got it to seperate but will not come out. tried prying as much as i dare, tried using trim cylinders to push it out, ot it out about inch and a half, but it pulls right back in. i am new to boats but have been a gm and heavy equipment tech for 20+ years, don't know what else to try short of a sledge hammer or 5 gallons and a match. any help would be appreciated
    scott
    Morgan Hill
    Quote Originally Posted by payton1803 View Post
    scott
    The 88 OMC is a Cobra, very similar in many ways to the Mercruiser.
    If it just wont come out, it may be hydraulically locked into the torque coupler.
    Would be wikking to bet the alignment is out of whack and causing it to grab, you can always loosen the motor mount adjustment towers and raise/lower the engine to try to find the sweet spot.
    Another little stupid trick to try is to have someone turn over the engine with a wrench while attempting to pull it off. Remove the coil wire for safety reasons.
    These can be a bitch.
    Good luck
    GT
    Jun 2013
    milan new hampshire
    motor is siezed so i can't turn it, is coupler on flywheel rubber mounted? how much flex is in it, i ot it out over an inch. don't want to destroy anything but at this point i may not have a choice
    scott
    Dec 2012
    scott
    Netrual ???
    Morgan Hill
    Quote Originally Posted by doubleeagle View Post
    Netrual ???
    Does not make any difference neutral or not.
    Try raising and lowering the engine.
    The torque coupler is a rubber hub and there is not a whole lot of slack in them, more importantly, impact will do nothing.
    You may be able to shoot some penetrating oil onto the splined shaft with a straw on a can of penetrant.
    GT
    Jun 2013
    milan new hampshire
    finally got it apart, splines were rusted to drive hub, no grease on the splines at all, now i can pull engine
    thanks all for the help
    scott
