While I wait for the machine shop...
Results 1 to 14 of 25
    Loose Nut on the Wheel michaellone's Avatar
    Duncan, SC
    Default While I wait for the machine shop...
    As I am (im)patiently waitting on the machine shop to finish up with the short block, I thought I might pass the time on the Forum Dyno. Just see what you guys thing about the parts I have been able to scrounge together and any ideas on what it will be able to make. Here goes the list:
    Merlin tall deck BBC, 4.60 bore (zero decked)
    Forged steel Scat crank, 4.50 stroke
    Scat 6.8 H-beam rods
    Dart 345's, mild hand porting, polished chambers and exhaust
    (chambers measure 122cc, pistons 39cc, head gaskets 4.630 bore at .040 thickness)
    Weiand Team G intake
    Comp aluminum 1.7 rockers and stud girdles
    MSD Pro Billet distributor and 6AL
    Holley Dominator 1250
    Lunati Solid Roller (see cam card below)
    All of this running on VP C-14 fuel. When I get more money, I plan on upgrading the cam, intake, ignition box and carb... but the money is running thin and race season is just around the corner. Let me know what you guys think.
    Mike
    Duncan, SC
    175 views and ...
    Southwest corner AR
    Ok 850 HP range! I am better on the 4.00 - 4.25 stroke motors!
    WT
    WFL Crew!!!
    Duncan, SC
    If it makes 850 hp, I would be happy. As of right now, I am less than $6000 in to this motor. Almost all the parts are used, just picking up deals as I can find them.
    Mar 2010
    Clarksville, TN
    Put a Tunnel Ram on it and you'll be north of 900
    Duncan, SC
    Bet I could pick up 50hp if I put a tunnel ram on my Honda.
    The reason I want to try to stay with a single carb is to make it easier to tune at the track and hopefully make it more consistent. I am shooting for the 9 second class and think I may have to back it up to stay in class. That being said, if I am running 9.20's... I may be looking for a second carb.
    It works but I do not like spinning a 41/2 stroke that high. Get good light pistons and rods. But I know nothing. Just ask anyone.
    How high? Did somebody mention RPM. These threads are so hard to follow.
    Duncan, SC
    Cam sheet says "3800 - 7400". I have a feeling that due to the heads it will run out of breath around 7000. Either way, I should have to put it on the rev-limiter to keep it in class. I have been using the chip to get me with in a tenth and dialing a degree or two of timing to get it on the number.
    Southwest corner AR
    I was just going by the cam card's numbers and 7400 would be high without a real good oil pan or external oil system for a 4.50 stroke! JMO!
    WT
    WFL Crew!!!
    Duncan, SC
    I ordered the pan from Armando and it should be shipping out tomorrow. As soon as I can come up with the cash, I will be running a 3 quart oil accumulator as well.
    Mar 2010
    Clarksville, TN
    WT likes them Armando pans
    Is it the boat in ur pic?? Seems like I have seen it a few times @ the Ky lake races . Did you run RR?? Hope to make a few races out there myself this year .. See ya out there Michaellone
    Duncan, SC
    Yep that was me! Kind of hard to miss that tail-dragger that looks like it was attacked by a 10 year old with a box of crayons.
    I have been running the 12's for the past 3 years and really trying to step up. We are removing the flat-bottom style rudder and replacing it with a real out-board rudder. Also changing out the strut and moving it back where it should be for a hydro.
    Planning on making the First race in June and then going strait to Wheatland. If all goes well, I won't be terrorizing the 12's no more.
    Quote Originally Posted by michaellone View Post
    The cam card ALSO says 396-454 not a 598. I would be surprised if that cam could carry a 454 to 7400 let alone a 598. You run out of cam long before you run out of port.
    Anyone ever notice that Lunati cam cards look like "cam cards for dummies"? Is the "lift at valve" net or gross, and how do you know? What is the lobe lift!!!!!!!
