Fuel pressure regulator install pics needed
Results 1 to 8 of 8
    Senior Member N2GLOCK's Avatar
    Oct 2010
    Default Fuel pressure regulator install pics needed
    I recently purchased an electric fuel pump that came with a seperate regulator. Looking for some install pics so I can get some ideas. Thanks in advance.
    Southwest corner AR
    Quote Originally Posted by N2GLOCK View Post
    With bypass or without?
    WT
    WFL Crew!!!
    Oct 2010
    I haven't a clue. It's the one that comes with the Holley Blue pump.
    Redding, CA
    This is a Blue pump and the 2 port, NON-bypass reg. that comes with the blue pump.
    I have a #8 line feeding it, with 2ea. #6 lines out to 2 660's. The PSI gauge is on one side of the reg.
    I now have switched to 2ea. 750 Holleys with dual feed inlets. So will post up a pic of that set up today sometime.
    It now has a single #8 out of one side of the regulator with a PSI gauge, to a fuel block with 4 #6 lines to the carbs.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Mar 2010
    Clarksville, TN
    I will get a pic tonight but I mounted the regulator right off my fuel pump
    Rancho Cordova. CA
    Here is mine...
Name:	san antone 2007-60.jpg
    Douglas, MA
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    I have a plate that covers the thermostat hole, it was made as a mount for the fuel log. I made a bracket out of aluminum and mounted the reg there, works for my application.
Name:	cole tr-2 2-18 fuel n water systems.jpg
