MERLIN X Aluminum Block
Results 1 to 14 of 37
    Longtime Lurker cougartunnel's Avatar
    Sep 2010
    Kelseyville, Calif.
    Default MERLIN X Aluminum Block
    World Products - MERLIN X Aluminum Block
    Check out the above link, Has anyone here on the boards used one of the Merlin X Aluminum blocks and if they have did you have any problems with it.
    The engine will be a 565 c.i. Blown and Injected on alcohol and will build about 2500 horsepower.
    I need to know if this block will fill my needs for reliabilty.
    I have heard a few horror stories about them.
    Senior Member Pattymelt18's Avatar
    No way will that block last. The worst casting in the business. Go wiyh donovan or dart.
    I have never built a Merlin with that much HP. The last one I did build needed to be line bored and the lifter bores were off and had to be bushed. Basically re-machined the block, had to square it all up. If going BBC based I would use Arias. That is what I used when I built stuff that big. Go Hemi.
    Jun 2011
    spokane, wa
    Mike Miller has a nice Donovan with pan for sale!!
    Kent, WA
    Seen one of them in a 540 blown alky deal in the 1500 hp range.
    Second pass in a drag boat, split # 2 main web.
    Replaced the block with a Dart cast iron, same guts, made 1545 hp on the dyno ?
    Didn't have any trouble after that !
    Sep 2010
    Kelseyville, Calif.
    Yea thats the horror stories that i have heard that the problem with the blocks are in the main webs !!
    and that they cant handle the big horsepower numbers.
    Senior Member Red Rocket's Avatar
    winchester, ca
    If you're truely building something with 2500 HP no cast aluminum block is gonna hold up. You will have to have a billet piece.
    Quote Originally Posted by Red Rocket View Post
    What about the New Century? The KB 6000series will handle it. So would one of the Trick Flow/Sonny Leonard blocks if you could find one. All there was up till not too long ago was cast blocks at more than twice that HP. There's more to it than just HP as far as what a block will handle.
    I agree you'll need a dedicated-design race block if you're going aluminum and that much power, not just an aluminum BB Chev. reproduction, which is what the Dart and Merlin alum. blocks basically are. That kind of power will turn them into scrap, the Merlin especially. I don't think the Brodix 8B would be up to it either.
    Kent, WA
    New Century is the best cast block in my opinion !
    Senior Member raysoninoz's Avatar
    Western Sydney NSW AUSTRALIA
    Hey wiz, could you give us a bit more info regarding this block?
    Who make these or is this a manufacturers name?
    Cheers
    Mediocrity is NOT an option...
    Ada, Michigan
    Here's the Arias / New century block,
    What makes this a better design is that it is a Y block with cross bolted main caps. Some call it a skirted block.
    If you get the 10.7 " deck and use a tall deck manifold with spacers and 1/8" gaskets on one side and 1/16 gaskets on the other side, everything lines right up. That takes a 7.3" connecting rod.
    I've got 12 years and many hundreds of hours on mine.
    Here's the link to New Century Performance,
    http://www.newcenturyperformance.com/
    Great people to do business with too.
    New Century....618-466-6383
    Lake Havasu
    I use a KB600 on my alcohol motor. Doesn't make anywhere near 2500hp, but according to the guys at KB a lot of the pro-mods use that block.
    Donovan makes a nice block but for what you are doing I wouldn't use anything less than their HC800 block.
