Piston swap
Results 1 to 3 of 3
Piston swap
    Senior Member Flat BROKE 612's Avatar
    Feb 2010
    Bumblefvck PEI
    Default Piston swap
    Pulled a piston the other day...
    If you love someone set them free, If they come back with the cops...RUN!!!
    Jan 2010
    So Cal
    What kind of ring gaps do you set on those
    Feb 2010
    Bumblefvck PEI
    Quote Originally Posted by 28Eliminator View Post
    Pretty sure that the .004" per inch of bore will be right out the window...
    I removed the old piston rings from the turbo manifold using a shovel....
