Help!! Double Pumper or Vacuum Secondary carb????
Results 1 to 5 of 5
    Jul 2011
    Default Help!! Double Pumper or Vacuum Secondary carb????
    What carb do I want? Double Pumper or Vacuum Secondary?? And WHY????
    Stock 454 bottom end
    Peanut port heads
    Edelbrock Air Gap intake
    Comp Cams Marine cam 0.564 lift
    Its in 17.5 Cee Bee Avenger
    Peoria, AZ
    For applications that are for general fun and performance I prefer Vacuum as it is more forgiving being that it is not as sensitive to tuning. If you are looking for every last HP then a double pumper might be the way to go, but they can be more finicky with throttle response.
    Paul
    With what you have I would probably use a Holley 3310 as it is a 750 Vacuum secondary setup. If you have an open engine compartment and you don't have to worry about LEO bugging you about "marine hardware" I would go with something like this.
    Holley 0-3310C 750cfm Factory Refurbished Carb | eBay
    The Right Coast/SE-PA
    Tested and tested my 850 annular DP, it gave a little harder hit but zero top speed gain or RPM and used a LOT more fuel > bigger and DP ain't always better.
    My Holly 715 vac secondary all around kicks ass. For my application I feel a 750 vs would be ideal.
    468, 049 heads nicely worked, roller Lunati Cam, Weiand Stealth, Aggressor full-A impeller = 5400 rpm
    Like Hammerdown said, there is no reason a vac secondary can't deliever the same top speed as a similar sized DP. It may give up a little on a well tuned DP in acceleration. But it doesn't have to give up anything on top speed. It may need a secondary spring tuning to equal the DP on the top end, but thats about all.
    With a dual plan manifold and a mild performance engine, its not going to accelerate all that hard anyway.
    I would go with the vac seconday.
    Orlando.FL
    X 2 Vacuum secondaries work well
