Another location to tap into the manifold for boost pressure
Results 1 to 8 of 8
    Silverdale, Washington
    Default Another location to tap into the manifold for boost pressure
    I'm thinking about adding another spot on my manifold that's drilled and tapped so I can have boost referenced carbs and a boost guage.
    What are your thoughts for the spot I've marked below with a black Sharpie pen?
    Sure dont want to add a spot and have it in a bad spot....thanks for the help..john
    I personally would stay away from a single runner and go to a equal plenum area. In a runner you could get pressure flutter as the valve train works. Somewhere around the pop-off shown in the picture would be my choice. The reason is it's not singled out to a runner and equal is in the plenum only. Pressure fed is only in the plenum and whats behind door #1-8 changes pressure. I think that would explain the flutter theory. M
    Olympia, Washington
    John why not go to the left a little of the other port?
    Senior Member cruzer's Avatar
    Chandler, Az
    Why not Tee of the guage line?
    Cruzer
    21 Eliminator Daytona. Blown 540
    Wet
    Wet is offline
    East Hampton, CT
    Got enough room to drill and tap the pop off?
    Thanks for the replies guys. It's much tighter than it looks there and really no room to go just to the side of the existing port. The popoff is a great idea but there no room there either.
    Guess I'll just settle on a T like Cruzer suggested. Thanks again......john
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    To the right of the pop off in the face of the manifold behind the dizzy.
    MI
    Quote Originally Posted by 500BBC View Post
    That's where mine are at.
