Remote Oil Filter
Results 1 to 14 of 65
Remote Oil Filter
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Default Remote Oil Filter
    Before or after the cooler?
    Senior Member GRoper's Avatar
    I'd say before to keep junk out of the cooler if anything comes Loose. Not based on any professional experience or knowledge just my opinion.
    before...keeps junk out of the cooler and hot oil filters easier.
    S CP
    S CP
    That too!
    Although I completely agree that it should go thru the filter first for all the above reasons, has anybody ever looked at the flow path of a Olson block mounted cooler?
    Phoenix
    Should the oil in the cooler flow with the water or against it?
    Everything is 3/4" if that matters.
    Unless it's absolutely necessary, I don't recommend remote filters. If it's necessary, it doesn't matter before or after. Just keep everything as close to the engine as possible.
    I have to agree. Unless the cooler has a built in filter arrangement like a H&M or a Olson, I would use a bypass sandwich plate at the engine that the filter mounts to. Running lines from the engine, to the filter, then to the cooler, then back to the engine is unnecessary and causes undue pressure loss.
    Senior Member shan's Avatar
    Yuma
    Quote Originally Posted by OLD MAN ON THE LAKE View Post
    Against. This maximizes the temperature difference between the oil and the water along the length of the heat exchanger = more heat transfer.
    Quote Originally Posted by Spike Morelli View Post
    Golfers and Fishermen are third rate bullshitters, compared to lots of hot boaters....
    Phoenix
    Before and against it is.
    Thank you gentlemen.
    Quote Originally Posted by shan View Post
    Does it?
    Bullhead City, AZ
    Does it?
    Any dyno or documentation on that ? Interesting topic ?
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Phoenix
    Shan is a mechanical mastermind.
    Don't doubt him.
    G.M.doesn't
    Quote Originally Posted by Squirtin Thunder View Post
    No dyno data. Its not really something you measure on a dyno.
    There is reams and reams of data to back it up. Most is useless info because its pretty much simple physics But every heat exchanger is routed like this one.* You can move the water in and outs, or the oil in and outs so they are on the same side, so long as they stay on the same end of the exchanger. You only have to pipe one wrong to see why its wrong. Specially when you are aiming at a specific thermal exchange, and your off by a country mile.
    *unless there is a reason to do so other wise, which off hand, never seen, and can't really think of a reason to do it reversed.
    Of the rougly 10,000+ heat exchangers I have seen in the past 40+ years, I have never seen one plumbed differently.
