Oil cooler or no?
Results 1 to 14 of 15
Oil cooler or no?
    Jul 2010
    Lubbock, TX
    Default Oil cooler or no?
    I don't have an oil temp gauge (though I realize that's the way to know)...but based on others knowledge; do you guys think I need one?
    Engine is a 550 hp aluminum LS1.
    Cruise RPM is 3500-4500 rpm; max rpm is 6100 rpm. The boat is a jet boat with a stainless B impeller.
    "No, my boat doesn't need any more power" - No one ever
    Quote Originally Posted by FormulaZR View Post
    how far/long do you cruise?
    how big of an oil pan?
    At those engine speeds that is some hot oil after a few miles.
    S CP
    Jul 2010
    Lubbock, TX
    I move all the time, so cruise length varies depending on the size of the water....but typically in the 1-3 mile range; not short by any means...sometimes up to 10 miles.
    The oil system holds 8 quarts.
    Fuel is premium unleaded.
    I was looking at the thermostat controlled units so that I don't have to worry about oil being too hot/cold.....
    what oil do you use?
    A cooler wouldn't hurt you one bit, you'd be surprised as to how hot your oil gets. You should see about putting a temp gauge in at the oil filter just to check.
    S CP
    Ada, Michigan
    The mistake I made was I put the cooler on at the same time as I put the gauge on.
    Then I realized it takes a long run at high speed/load to get the oil up to even 220 without ANY water flowing through the cooler. Now it's all plumbed in and I wish I didn't have the heavy ass thing on there.
    Jul 2010
    Lubbock, TX
    S CP
    Mobil 1 10w40.
    I will probably heed the advice and put a temp gauge on first. My theory (which could be wrong) is that using a thermostatically controlled oil cooler would help both scenarios...
    Mobil 1 10w40.
    Good oil... and yes a thermostat on the cooler is a good idea
    S CP
    Jul 2010
    Lubbock, TX
    The only thermostat controlled remote oil cooler I can find is the one sold by Hardin. Are there other/better ones out there? Maybe one that includes the oil filters as one piece like the one GN7 posted in another thread?
    $$$$ and they take up space.
    S CP
    S CP
    Here Jon, let allow me to fix that a tiny bit.
    They do take up space. But compared to a remote filter and remote cooler, not really. The only benefit to the seperate pieces is you can splkit them, but then you adding unecessary line length.
    I kind of giggle when I think what I paid for that cooler. The second one I bought was a little more, but still roughly the price of a used remote Olson.
    at the end of 10 laps what's your temp?
    S CP
    Senior Member shan's Avatar
    Yuma
    240-250
    Perfect. For a grouchy old bastard! Sorry, I've been painting (my shop) all day and in a mood.
    Quote Originally Posted by Spike Morelli View Post
    Golfers and Fishermen are third rate bullshitters, compared to lots of hot boaters....
    Quote Originally Posted by shan View Post
    Thats using the water exiting the superchiller.
    We can get it 260-275 with the right straight 50 conventional. Higher on a course like Puddingstone.
    I am only a grouchy old bastard when on the key board. My fingers are total pricks. I am, on the other hand a mellow, grandfatherly grey hair.
