Our Twin Turbo analysis.
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 125
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Our Twin Turbo analysis.
    As many know we built a twin turbo with the guidance of Mark Unchained. Got it going late in the season last year. Made way too much power. I was told it would by Mark and Hass. Had a few problems and eventually kept it in one piece.
    Spit the belt driven fuel pump drive out one day testing. It lean popped but seemed OK. Had low boost one test session and found a silicon coupling was blowing loose under boost. lol. Lost oil pressure one day testing and found the crank had flexed hard enough to knock the oil pump loose. Had clearanced the pump to clear the crank during assembly. Caps had walked pretty hard. Changed the bearings and took some timing out. Put one piston in the lathe and opened up the ring grrove where it had pinched rings a bit.
    Missed the race we were trying to get to.
    Got it going again. It ran so hard almost blew it over testing. Killed another set of bearings. Missed another race. Caps walking pretty bad. Crank was not pretty Our friend and Shazam CC Mike Boyce said it has to be timing. Crap we are running methanol 9.4 compression and only have 33 degrees of timing. Called Brodix and they confirmed 31 degrees max with the Head Hunter heads.
    Decision time. Wanting to get to the World Finals. Asked Info Jr. what does he want to do? All we have time to do is roll in another set of bearings and back the timing off. We decided to go for it. Make a few passes and check the oil filter. If it's good keep going, if it's ugly pack it up and bring it home in one piece
    Set the timing to 27 degrees went to the WF made a couple really good passes. Checked the oil filter and it was ugly. Has to be an oiling issue.
    Brought it home and didnt touch it all winter. Pulled the engine a couple of weeks ago. It had only killed the rear main bearing. Everything else looked great. As it turns out the rear main on the crank was not happy and the block line hone on the rear main was not either.
    Analysis. Damaged it with too much timing. Did not have it apart the last time to find out the crank and block was not happy.
    Just set the engine back in the boat yesterday. Ground the crank and line honed the block. Put a Titan oil pump on it. Thanks Steven Gearhead. New piston for the one we repaired. Should last all season this year.
    Current challenge: getting control of the boost.
    Couple pics of upgrades. Oil pump and bigger oil lines going to the Oberg filter. Moved the corner of the oil pan out to clear the pump. Very lucky it was so simple. Info Jr. getting the boat ready to drop it in.
Name:	Engine back in 4-2012.JPG
ID:	158399   Click image for larger version.
Name:	oil pump 4 2012.jpg
ID:	158400   Click image for larger version.
Name:	oil pan mod for pump.jpg
    QE 439 Twin Turbo
    As many know we built a twin turbo with the tune up guidance of Mark Unchained. Got it going late in the season last year. Made way too much power. I was told it would by Mark and Hass. Had a few problems and eventually kept it in one piece.
    What block/crank are you runnig? What kind of brg clearance?
    Who's doing your machinework??
    ha ha...j/k...
    Mike Boyce...great resource there.
    New Port Richey, FL
    ha ha...j/k...
    LOL thanks. Yes Mike is. I do know what timing most run on blown alcohol hemi head stuff. And 33 would be too much. Who would have thunk 31 degrees max on a typical Pinch head Chevy? Non LS style. I guess the latest greatest stuff is pretty effecient.
    QE 439 Twin Turbo
    Glad to hear you didn't kill it.
    One nice project.
    check your pm's
    S CP
    Senior Member bp298's Avatar
    LHC
    good job ron. what's your race schedule look like????
    ha ha...j/k...
    Look at it this way, you've changed the moment that peak cylinder pressure occurs so you must change the amount of ignition lead to prevent hammering the piston as it approaches tdc. 33 degrees is too much advance with any decent amount of boost, nitrous etc.
    13-15 degrees advance is a good starting point when the engine sees full boost then you can read the plugs and add timing advance back in if the engine wants it.
    New Port Richey, FL
    Interestingly enough. Spark plugs looked great bearings and main caps not so much. pistons looked great also. Except for 1 lol
    QE 439 Twin Turbo
    I'm thinking if I can pull out up to 12* with a 300hp Nos shot, then 20* ( total )as a starting point with boost seems reasonable.
    S CP
    You may have a timing issue, but I don't think that is the whole story. I think you had oil issues as well. The greastest tune in the world can't save your bearings if you have oil issues.
    Granted, there is a timing factor in a boosted engine. But fuel and flame speed play a part as well, as does charge density.
    16 plug Hemis on nitro run 50+ degrees. That chamber is pretty damn efficient. So something else is determining the timing besides chamber efficiency and boost pressure. Think it might be the fuel type and charge density?
    I can knock the hell of set of bearings. We did at the Puddingstone race. But the worst damage was the pistons. The closed ring land tells you something. But still not so sure the bearings is 100% timing. I think the oil system changes were a good idea. Wouldn't surprise me if your back around 30-32 when you get it figured out.
    New Port Richey, FL
    After I posted the sparkplug response I thought about the piston. It was #8 that pinched the rings and it was the rear main bearing hurt. I doubt we get the timing back up there. It doesnt need it. But we didnt know that until we got it on the clocks.
    I really want to get away from 2 injectors per hole. It won't loose a hole if one goes bad. Driver can't tell.
    I have both from #8 out and am having them tested tomorrow.
    Plan is running Div 2 Lucas BP. Won't see you until the WF unless you go to Marble falls.
    QE 439 Twin Turbo
    IMO those are awfully big heads for what you're doing. That doesn't help the tune-up window, especially with fuel injection.
    I probably would have started at about 25* given the rest of the combination.
    New Port Richey, FL
    LOL you would for sure now..
    I ran low compression blown alcohol with a hat for years at 36* and more. The only thing I had to compare it to.
    It was quite an inconvenience but not a disaster.
    QE 439 Twin Turbo
    LHC
    i've always liked marble falls. fun place to race.
    do you have egt's on each cylinder???
    okie, lake Texoma
    I know comparing our engines is apples to oranges as I'm on gas but Steve Morris recommended I start at 32* which he said was real safe, and then if tuned for max power he said i'd probably end up at 35-36. Thats with the BB2xrta C&Cd heads, C-16,intercooler and about 25psi. Locked Mag.
    I've been running at 31-32 and like you I have more than I need so no need to wring its neck.
    You know, this could be a whole lot more fun and way less work if we could get some control over the boost.
    Hope it stays together for you.
    H8-2-W8
    [email protected] first pass
