Made a "little" noise today
Results 1 to 14 of 26
    Default Made a "little" noise today
    Pulled the 342" ( 4.00 x 3.40) out of the Mustang Bonneville car and put it on the dyno. Dad had the build sheet from the guy who owned the car and it seemed like a stought little engine:
    The engine needs a little re-fresh as it over-heated 3 times at Bonneville and has a small water leak at a head gasket. We decided to run it to see what it makes for power. On the salt it would only pull 6,300 in 3rd which I thought was 400-500 below peak power.
    1988 Mustang Gt went 179.79 on the 5 mile course with this engine ........ 6,300 rpm and 62 psi oil pressure.
    Engine specs:
    342" ( 4.00" x 3.40")
    AFR 205 heads, ported ( no flow numbers...sorry)
    12.5:1 Probe pistons, Akerly and Childs rings
    Holley HP 750 carb
    Edelbrock Vic jr intake ported.
    Cam.. solid roller: dur at .050 254/266, .637/.657 lift, 110 lobe sep.
    So what's your best guess on power?
    Made a couple of pulls then pulled the Holley hP 750 and replaced it will my C&J Engineering modified Demo 750 with a Holley 850 base plate to see what it would do.
    Made a total of 7 pulls and was done.... 4 pulls with the Holley and 3 with the demo with a re-jetting.
    Best guess ? HP and trq w/ RPM
    I'll post dyno results tommorrow night.
    S CP
    Green Bay Wi,USA
    I will guess 509 hp at 7200.
    See edit
    S CP
    Mmmmmmm.......I am guessing.......150 less than a crate 5.3 LS
    526/6700 and 480ft/lbs at 5100.
    bite me.................
    S CP
    475/5000-5100
    My guess going into this was 525 @ 6,800, 425 lbs ft @ 5,800:
    Yesterdays results with the HP 750 with dyno headers 1 3/4":
    495Hp at 7,000, 407 lbs ft at 5,900
    With modified Demo 750 with an 850 Holley base: C&J Engineering
    from 2004
    507 hp @ 7,000, 413 lbs ft @ 5,400
    Today: With Kooks stepped/merge collector headers 1 3/4 - 1 7/8" Fox body headers
    520 hp @ 7,000, 420 lbs ft @ 5,400
    engine was making 517 @ 7,200 where we stopped
    We made two pulls and were done.. second pull made peak of 518 at 7,000 - 7,200
    We did a leak-down after the warm-up
    5 cylinders leaking 3%, 2 were leaking 4% and 1 was 5%.
    The guy who built the engine in 2005 advertised it as a 500hp 342 long block. This is a happy little engine.
    Heads will come off and we will check the bearings and it's ready to run another year.
    S CP
    Jon
    Very good guess for day 1.
    Who did you talk to ?
    S CP
    Steel and I were on the mark. Might be able to run 91(10 to 1) octane. HP strong, whoop that trik again!
    While the heads are off, check for a lump on the piston!
    I thought in the original post Sleeper said it had 12.5 Probe pistons.
    I think he's suggesting it's not 12.5:1 as advertised.
    I think it is.
    S CP
    The basics from a couple of pulls:
    S CP
