Timing chain
Results 1 to 6 of 6
Timing chain
    [email protected]
    Ohio
    Default Timing chain
    I'm going to replace my double roller chain. Is there any prep I should do before installing it to get the most life out of it?
    Newton Ks.
    None I am aware of.
    H.L. Mencken
    A good soaking in oil prior to assembly would be a good idea, insuring instant lube between the link pins and actual rollers. I do the same with roller lifters, hyd. lifters, and roller rockers. You can not have to much pre-lube on initial fire up.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Just for the thought some of the old racers would actualy bead blast them to hold more oil on the sufaces unless you drill the lifter galleys for alittle spray of oil the only oil they get is splash and run-off. IMO M
    waterloo
    Are you serious? I am a young guy I guess.
    (If a BBC) Check the wear area behind the top sprocket. The factory put those two .040" ish holes in the oil galley plugs for a reason. Many a guy does not bother to drill the holes when changing plugs.
    Wags
    +1 what Larry (bubbletop) says
