Magneto help
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 48
Magneto help
    Senior Member rvrskir's Avatar
    Lakewood, CA
    Default Magneto help
    I have a mag on my boat that hooks up to a mag signal converter then to the tach. I just bought a new tach (old one didnt work). it starts off at the right RPM (for about 5-10 secs) then it starts moving up in RPMs then just dances all over. Is the tach set wrong or is the mag interfering with the signal?
    1973 Rogers Cyclone- 16' 6"- 350 SBC
    1976 Hondo Pantera- 18'- 455 BBO
    Quote Originally Posted by rvrskir View Post
    Whos mag and who signal converter. If MSD, what part number.
    okie, lake Texoma
    I've been running mags for a long time and have tried atleast 3 different times to make the MSD & Autometer converters work without any success. I have one of the last mag tachs that autometer had on the shelf and dread the day it quits.
    This is the only alternative that I am aware of at this time.
    Tach Parts
    H8-2-W8
    [email protected] first pass
    Default Tin foil hat....
    Try wrapping the converter box in tin foil. I was told those converters pick up ignition "noise" in the air.... It didn't work the only time I tried it, maybe the foil was too thin.... But that was Autometer's suggestion...
    I was un aware that Autometer quit selling "mag" tachs???
    Ray
    LOUD BOATS SAVE LIVES
    Lakewood, CA
    Joe Hunt mag to an original suntach signal converter
    Lakewood, CA
    and now that i post that picture i think i might know why. Duh! gotta adjust the screw!!!
    okie, lake Texoma
    Ray
    Yes , 5-6 yrs ago when I bought the recall tach for the mag in my boat the Tech from autometer told me that I was lucky to get it as they werent going to build them any longer and the one he was selling me was his last one. He said that there was some component in them that was just to expensive to build.
    H8-2-W8
    WOW!!!!! Where did you get THAT!!! I haven't seen one of those in 40 years.
    THAT IS NOT A MAG SIGNAL CONVERTER!!!!!!!!!!!
    Its signal box for a 60's Sun tach. In the olden days, tachs like the Sun required a seperate signal box to work. That box is useless for anything other than driving a Sun tach from a mag. If you're trying to run a modern tach with that box from a mag, it will not work. If you're trying to drive a Autometer tach, you need Autometer part # 9118
    If you ever run across a tach that looks like this, you have a converter drive box. The tach is useless without one, and the box is useless without the tach. This one is for a 12V ignition system, but the tach is the same. Only the signal box changed.
    Tower Park Resort, Lodi, CA
    Correction... THOSE.
    Apparently he has a couple. One with a red tag and one with a yellow tag. By the looks of them, I'd say they're a product of the 1950's-early 60's. Reminds me of my dads American Flier train set transformer.
    Funny that the solution may have been as easy as reading the bold print on the unit. LOL We'll see I guess.
    Senior Member bp298's Avatar
    LHC
    when i first bought the sw 17 years ago, it had a autometer recall tach that worked just fine with the vertex mag that was on the engine. when i converted over to msd about 20 minutes after i got the boat, i sent the tach to autometer and they converted it to a "normal" tach. tach still works fine with msd. i would think they could convert it back if a person wanted them to.
    and the vertex is still in a box under the bench... best place for it...
    Not real observant there Budweiser. I believe thats the same box, and the lighting makes it look different colors. Unless both boxes have an identicle rust makings on the signal trim srew.
    Ah hah! Right you are... AGAIN.
    okie, lake Texoma
    I'll take it off your hands if you think its of no use to anyone.
    H8-2-W8
    I think Bob is considering using it to build an electric chair for some rodents.
