looking for 420 megablower info
Results 1 to 7 of 7
    Member DirtyJohnson's Avatar
    May 2010
    Default looking for 420 megablower info
    I can't find any info online for these, not even a manual. I do have an original B&M catalog section for these but it doesn't show much other than pulley ratio's. It does show it can be overdriven 27%.
    What is the capability of these, max boost and HP on a BBC?
    Kingman/Golden Vly, Az
    Quote Originally Posted by DirtyJohnson View Post
    I can't find any info online for these, not even a manual. I do have an original B&M catalog section for these but it doesn't show much other than pulley ratio's. It does show it can be overdriven 27%. What is the capability of these, max boost and HP on a BBC?
    from what i know, these blowers were originally built by B&M with a 6 or 8 rib serpentine belt set-up with a 16 rib optional...when Holley bought them out, they changed over to an 8mm set-up (much better)...i have a Holley 420 with the 8mm set-up with a Superchiller under it mounted on a special designed for it manifold with a v-shaped floor (^)...better fuel distribution vs the old style plain flat floor...also...the top of my blower has the carb flanges built in to it for 2x4 4150 carbs to run in-line or sideways...i'm also told, these blowers are a cross between a 671 & 871...when i get my 496 together, i plan on running this pkg with either 2 Holley 450 DP or 650 DP mech sec carbs @ 5% under driven...i dont know the capability or max boost etc of these blowers, but, i would think they will handle quite a bit of boost...there is (i think) some one on the boards that is running one of these, maybe more...they may read your post and respond...i hope this helps a little
    May 2010
    Most of that I already knew. I do have the 16 rib and according to your description the old style intake. I too am superchilled. Between the 2 belts they each have there pro's and con's from others I have talked too. The 16 rib was designed for boats to allow the belt to slip in case of a backfire because there is no explosion plate on boat manifolds. If I was you I would run 750's and I happen to have a pair from mine for sale.
    I most interested in what kind of power potential they have and max boost the blower can handle.
    May 2010
    No one has any info?
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Call TCM
    They built a lot of engines with mega blowers.
    May 2010
    I can call them, that is who originally built it.
    Senior Member Meaddaytonamike25's Avatar
    Jul 2011
    Pm sent
