Help! 496ho won't go over 4000 rpms or over 40mph
Results 1 to 12 of 12
    Question Help! 496ho won't go over 4000 rpms or over 40mph
    Max rpms 4000. No beeping or anything. Hooked to computer and no codes. Changed spark plugs and new fuel. Same thing. Help?!
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by dannyo View Post
    What's the fuel pressure - KOEO?
    Mar 2010
    Clarksville, TN
    Check your linkage/throttle cable and check your timing
    Sorry. How do I check that? I don't think I have a gauge?
    Thanks, Dan
    Throttle cable was replaced recently and ran great last 2 trips.
    Bakersfield, CA
    If you don't know how to check the fuel pressure, don't bother. Have someone check it next time during service.
    The next thing I was going to mention is - throttle cable....has it been touched recently?? Without guardian codes (beeping and limiting RPM), it can really only be lack of full throttle extension from the cable. My bet is it came loose.
    Disregard the timing, you can't check that without being hooked up to a laptop. No distributor whatsoever.
    Thanks for the suggestions. Plugs changed, Fuel pressure stable, no misfires when lake tested. Gonna Compression test but still can't figure it out.
    Quartz Hill/Havasu - Where Life Leads US
    May want to check the water pressure sensor. On the HO there is a little T that checks that verifies water pressure on the intake. Mine has developed calcium and the boat felt like it wanted to come off plane and not go any faster. Once cleaned all was good.
    Member emilsr's Avatar
    Jan 2012
    El Paso
    4k rpm/90% power is soft guardian mode. Surprised that it didn't throw a code assuming your throttle is open all the way.
    Will check water pressure. Yes, no codes at all.
    Jan 2012
    El Paso
    That's odd....
    I know the software varied a bit through the years ('01-'11) and have heard a couple of stores about the IAC going bad without any beeps or logging a code in certain years. This put the 'puter in soft guardian mode. A friend had this happen recently in a 2003 model boat....chased the problem for over a month.
    Hate to even suggest just throwing parts at it, but if nothing else take the IAC to your local NAPA or VatoZone and cross reference the part number. Mercruiser sells them for about $100, but it's a Ford part and NAPA has them for about $60 (last time I checked). Once you install it you'll need to have the 'puter reset to take it out of guardian.
    .....if that's even it. Hopefully you'll find something simple before then.
