need 460 help
Results 1 to 3 of 3
need 460 help
    May 2012
    Wink need 460 help
    i have a 460 .30 over that was internelly balanced roller rockers. i am looking to put a cam in this motor the engine info i have says it has a hyd hi perf cam but this thing doesnt lope. i am looking to make this motor lope good, nothing dangerously big but i want it to sound good. it has the over the transom headers (jet boat). any help out here and if you are in the menifee area how much would you charge to install this cam thanks in advance rich.
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Quote Originally Posted by BIG RICH View Post
    Comp cams xtreme marine and the have cams specked for a/b impellors mine has 585 lift and a mild lope sounds good with the open headers
    Senior Member cakeeater ed's Avatar
    huntington beach ca.
    just run a manual choke cable and pull it when your around the docks, going to another flat tappet with todays oil is risky even with lite brake in valve springs, If you must change cams, roller is the best way to go. as for the cost, remember you get what you pay for.
