where to pull oil temp on 460
Results 1 to 14 of 25
    Maple Ridge B.C. Canada
    Default where to pull oil temp on 460
    I want to install an oil temp senser on a 460. wheres a good place thats gonna get a good reading . theres a port beside the fuel pump block off plate. I'm thinkin good flow being close to filter
    Apr 2012
    in the pan. tap the drain plug and screw it into that. if you mess up there cheap and easy to start again
    that looks really tricky with the motor in the boat! I agree the pan oil temp would be ideal.
    Oil pan.
    If not oil pan you could always try placing a temp probe in an accecesory port of a remote oil filter mount:
    the port on the top of this Moroso unit
    S CP
    Quote Originally Posted by rogerroost View Post
    I think you're suppose to remove the plug and do it on a bench. Just a guess
    why you gotta be like that? I think you need a hug! I thought i would try drilling & tapping thru the bottom of the hull.
    the huge 90 degree fitting on my basset pan just clears the hull. I don't think it will unthread without lifting the motor. therefore the question about the port that i can get to with ese,which (i think ) would be similar to being on the remote filter.
    I'm thinking you might disrupt the oil path( flow) if you use that port at the front of the engine.
    S CP
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    I think mine is down by the fuel pump have a tube that comes out so the sending unit clears. I will get a picture tomorrow afternoon. Its dark now.
    Quote Originally Posted by 79sleek View Post
    Why not just put a tee in your oil pressure line and stick it there? Couldn't be any more inaccurate
    if you think that will be accurate. that was my concern . i didn't think it would be accurate due to the lack of flow. that would sure be easy
    I rather crazy glue the POS to the side of the pan!
    That's what they make JB weld for.
    S CP
    Whats it worth to you if this works in your pan and gauge? Should I tell you now where to send the money, or can I trust you to PM me when it works?
    LINK: drain plug sensor
    May 2011
    Wyoming
    Well guess your the pros, ive never had a problem, works fine. If you want a pic ill be happy to post one.
