Pan heater
Results 1 to 3 of 3
Pan heater
    COLE TR-4 BGF MEANSTREAK's Avatar
    Default Pan heater
    What kind of pan heater do you guys like the immersion or the stick on pad type. I am having Armandos build me a steal pan and would like your input. Thanks in advance.
    The probe type are cleaner and don't fall off. Easier to replace, and usually cheaper. BUT!!! Don't fall into the trap of thinking a water heater or some cheapie element is fine. You'll end up with a burnt out coked up POS in no time. They get too hot for heating still oil in a pan.
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    My Stef's pan(Thanks Steelcomp) has a screw in element, 8" cord with standard plug, does not contact the oil, heats up nice(Stef's installed it in my aluminum pan), you can buy the same element in Jegs for 65.99 part # 861 - 6771 (for steel pan), just bore a hole in pan add weld nut and screw in.
    Anyone can pedal a bicycle, can you pedal a flat?????
