scat cranks
Results 1 to 14 of 82
scat cranks
    Senior Member Ronboats's Avatar
    Norcal-Santa Rosa
    Default scat cranks
    simple question-is a scat crank any good for...700 hp or so?
    468 bbc
    Quote Originally Posted by Ronboats View Post
    468 bbc
    4340? EASY!!! Cast steel, marginal for the RPM you will have to spin a 468 to make 700HP.
    Norcal-Santa Rosa
    dont know if i will hit 700, but i dont want to use any junk. I am trying to justify buying a new rotating assembly rather than re-use whats in there now
    Senior Member Pattymelt18's Avatar
    The scat 4340 i have made over 800 and worked for three years flawlessly . Im putting it back into service this year. I think the finish work is much better than an eagle. If you wqnt a great priced fully American forged crank contact jon partridge at bullet cams. They make great American products for a fair price. All there forgings are from Louisville foundry which was lunati got them from.
    Jan 2011
    Mickleton, New Jersey
    Buy new
    Senior Member oldschool's Avatar
    What crank do you have? If it's forged Scat crank and is in good shape why not use it?
    Norcal-Santa Rosa
    Unhappy
    Quote Originally Posted by oldschool View Post
    I dont know if it's forged.all i know is it says "scat" on it and it now has two spun rod bearings. I havent miked it yet,but it looks like it might be toast.
    One of the bearing shells(both halves#6) was in peices wadded up at the oil pick up. the # 5 shell was still around the crank.The rest of the bearings looked good.I'm thinking the side clearance on those two rods will be a little big after the bearing was sqeezed out ...(I didnt have the pistons out yet when I asked about scat cranks)
    Stand the crank on the flywheel flange and tap the front counter weight with a hammer. If it rings like a bell, its forged. If its a dull thud, its cast.
    Those two rods are probably toast as well. If the crank needs to be turned more than .010, your better off junking it. You could buy a whole 496 rotator and gain some power at the same time.
    Norcal-Santa Rosa
    I was thinking the same thing.I was told about assemblies from White perfomance. Any other companies you would suggest?
    Drop Steelcomp (member) a PM. He is in your neck of the woods. He can set you up with a Scat rotator, balanced if desired.
    Senior Member bp298's Avatar
    LHC
    gn, santa rosa and nipomo aren't quite in the same neck of the woods. it would have to be a very long neck.
    Jan 2012
    Default 468 bbc
    i run a 468 bbc brodix heads,gm block std,4500 series carb 1050cfm,roller makes 886hp at 7000rpm
    Arroyo Grande
    gn, santa rosa and nipomo aren't quite in the same neck of the woods. It would have to be a very long neck.
    it's close enough..ups can make the stretch real easy
    Quote Originally Posted by dynodanbbc View Post
    That's pretty stout for a 468 with a single carb at only 7000.
