Mechanical fuel injection
Results 1 to 5 of 5
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Mechanical fuel injection
    What would be the pros/cons to converting to a "hat" from my holley dominator on my normally asperated 572? Peak power is 850hp at 5900rpm on E85
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    The MFI guru's might ask you engine build spec's, what do you want to do with it, parts you need and or have, intake, fuel to be used, etc.
    Anyone can pedal a bicycle, can you pedal a flat?????
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Master Sergeant View Post
    It's off or on and u will use more fuel
    Gone
    Sparks, Nevada
    The carb will work better. Leave it alone.
    Its a boat guys. Fuel consumption and drivability take a back seat to the bling.
    If it made 2 HP more across the board than a well setup T ram I would be very surprised.
