Geometry lesson time - Page 2
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 15 to 28 of 29
  1. #15
    No rotory table. I do see the indicate x and y and up and over. IF after indicating x, y is not also in line, that answers my 90* to one another issue. It will still take some work to verify the 45 to slot.
    Wags
    Do the up and over on the slot till it's exactly 45* on the table, then check the edges.
    waterloo
    Quote Originally Posted by earlbrown View Post
    just curious.... did you check the surface between the deck areas (parallel with the valley area) to see if it was square with the slot?
    No, I will before I remove it and rotate it though.
    Wags
  4. #17
    Senior Member lbhsbz's Avatar
    Long Beach
    The problem is that one of those surfaces has to be exactly 45* to the center slot (which should be pefectly centered on the hole). Checking 45* to the slot is the challenge. A rotary table would make it easy, or the "up and over" measurement.
    I'd make a snug fitting round pilot on the lathe to fit the hole on your plate and fasten that to your mill table to hold the hole position. Find your center using a coax indicator or whatever you use. Set the plate down so your slot is at a rough 45, then stick a test indicator in the quill....angle/details don't matter so long as you don't turn the spindle during the process...touch off, record your location, walk the X and Y up an inch and tap it around until you've got the slot at a perfect 45. Clamp it down, recheck, then clean up the deck sides of the plate on your x and y.
    Tower Park Resort, Lodi, CA
    Where is the "smiley" of an airplane buzzing over my head, damn it!
    I know I can comprehend this stuff, anyone care to explain all this mumbo jumbo?
    Where is Phil? (DIMARCO21)
  7. #19
    waterloo
    I think you hit the nail on the head. This will ensure the 2 angles are 45* to the slot. The x and y axis of the mill ensure the 90* to each other. Simply dial in distance from center hole to top of plate (+ 1/2 tool diameter)
    Wags
    I knew there was enough brain power on here to steer me right. THANKS GUYS
  8. #20
    waterloo
    I am double checking and correcting the accuracy of this plate. It is fixtured through the mains of a block. The slot uses a tapered cone deal to go into the cam bore. You then indicate and deck off of this fixtute ensuring deck height and angle. I just got this one with another mill I picked up.
    So, making it right.
    Wags
    BHJ Blok-Tru Blueprinting Fixture General Description: BHJ Products, +1 (510)797-6780
  9. #21
    Wags
    Have you checked to see if the slot is actually centered on the hole?
  10. #22
    Wags
    You really don't need to make the pilot, but that's another good way of doing it. Just get the slot @ 45, clamp the plate and indicate the hole for your zero.
  11. #23
    waterloo
    DAMMIT STEELE
    I had not thought of that. F me.
    Well, I got home late, but indicated the 45 to 45*. (well actually over a distance of 2.250" it was .0004" off). I didn't use the pilot. I went off the x axis edge to get close, then went from there.
    The x edge then was .0013 ish off. Makes sense. The distance was about 6" from end to end, so 3 x .0013... close.
    The y axis was about .0035 difference. SO, this edge must be the one that is an issue.
    So, my plan is to get the 45* slot on the money. (or an average of both sides of the slot). THEN I will double the x axis of the plate. I feel .0005 is close enough. Probably more than close enough.. I will then indicate from the hole center out to the x axis of the plate, cut it, measure it, marrk it, and its done.
    I will then go to the y axis, cut it, go to same distance on DRO on mill and call it good.
    THEN I will vow to never touch this thing again. ROFL!
    I will then send it to the prison, hae them make another one for me 1" thick and compare the 2. Throw this one away. Be pissed I spent all this time. Go drink beer.
    Wags
  12. #24
    DAMMIT STEELE
    Wags
    LOL...sometimes you gotta pick your battles. Sounds like you dun good.
    Beer.
  13. #25
    waterloo
    So, what is reasonable?
    I think .001 over the 6" plate is max allowable. Should be easy enough to obtain better. Deck to deck .0005 seems like it should be pretty easy to machine too.
    Am I to picky? To loose?
    Wags
  14. #26
    Wags
    I think +/- .0005 should be acceptable. Most block machines can't hold that anyway, but that shouldn't be the deciding factor. Get it as close as you can, and that's all you can do.
  15. #27
    waterloo
    That sounds good. I just didn't want to compound errors. Plate .001", machine another .001, stuff can add up.
    Wags
  16. #28
    Wags
    Thanks Wags.
    -Seth-
