PCV question/help
Results 1 to 13 of 13
PCV question/help
    Sep 2011
    Los Angeles
    Default PCV question/help
    i ran a 3/8 line from the neck of the pcv breather to the vacuum part (back of the carb). does this look right? i talked to someone yesterday after i sent a photo of it and he believed that this will probably lean the motor out. input and advice please. i'll probably leave the boat alone today and turn some wrenches tomorrow
    You'll be lucky if it even idles. That only works if you have a PCV valve in the line somewhere. The cap is not a PVC, and I doubt there is one screwed into the carb base.
    One some boats that line from the breather goes to a fitting that attaches to the side of the flame arrester r the line attaches to an fitting on the top cover or the base of the flame arrester, and the carb will simply suck in blowby as it exits the hose.
    DO NOT run the boat with the setup you have now!
    Tower Park Resort, Lodi, CA
    Default Yup
    Quote Originally Posted by larryfknrocks View Post
    Is that one of the billet breathers that actually has a PCV valve built in?
    Sep 2011
    Los Angeles
    thanks gn for that. i took it off the carb IMMEDIATELY and place the rubber nipple back on the carb. i do have a fitting on my flame arrester. do you think thats a more suitable place for it? is it an option to have this valve or can i just use regular breathers?
    Sep 2011
    Los Angeles
    yes it is
    yes it is
    Larry, before you say that, you have to fully understand what he is asking. He asked, is that valve cover "breather" have a PCV valve built into it.
    I have NEVER seen one that wasn't machined aluminum billet, or that didn't have a AN hose fitting. That APPEARS to be neither.
    The picture APPEARS to be a chrome steel breather with a plain hose fitting.
    Can you see the PCV valve in the bottom of this? Does yours look like this when you flip it over?
    Sep 2011
    Los Angeles
    no it looks like this
    Wow, thats a new one on me. Leave it to those Chinese.
    OK, now you have a different issue to deal with.
    The valve in that thing is a spring loaded check. It OPENS when the vacuum is high, and pulls "fumes" from the crankcase.
    BUT, it needs air to enter the crankcase or it can pull your pan into a vacuum. Thats not all bad really, BUT, when the vacuum goes away when you open the throttle, it will close, and your crankcase will be sealed. You have no breather on the other valve cover. PCV
    stands for POSTITIVE CRANKCASE VENTILATION, not crankcase vacuum.
    If you leave the setup the way it is, you will seal off the crankcase when you are driving, and blow the gaskets all to hell.
    There is a reason boats don't use PCVs. #1, they aren't required. #2, They don't really work. When you drive down the freeway in your car, yiour throttle is open so little that you still have manifold vacuum. In a boat, the throttle tends to be open too far too much of the time for it to work.
    Your MUCH better off with a setup like Budweiser posted. One hose off each valve cover. The engine will vent much better when the throttle is open.
    Sep 2011
    Los Angeles
    LMFAO!!!
    i follow what you are saying after reading this a couple of times. in a nutshell, i really dont have to use a pcv since it is not required, to eliminate a headache i could go with a good set of breathers?!? or stick with this and just get it plumbed right?
    If its a open engine compartment, I would go with two good breathers. You can even use the K&N push in type. If its a closed engine compartment I would go with a deal like budweiser posted, or leave the one you have and add a hose off the other valve cover up to the flame arrester. Open breathers on a closed deal can make the engine compartment a oily mess after awhile.
    You can leave what you have on a open engine, but you have to add the second hose from the other valve cover.
    Sep 2011
    Los Angeles
    i might just buy two breathers and call it a day... thanks for the help!
    Default PK, but.....
    Using two breathers MAY cause oil "misting" aft of those breathers. I use one breather, (not a lot of dust/dirt on the water so it's not necessary to filter the "IN" air of the system), and a PCV on the other valvecover. I have learned over the years it prevents the oil misting during hard runs...
    Ray
    LOUD BOATS SAVE LIVES
