Do zoomies need to be plugged while not running?
Results 1 to 10 of 10
    Senior Member norcal73's Avatar
    Lake County, Ca
    Default Do zoomies need to be plugged while not running?
    I have heard a couple of opinions around town where I live. Is it a wives tale about valves getting warped if you dont plug the zoomies after running an engine? And what do you use to plug them?
    norcal73
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by norcal73 View Post
    norcal73
    Tennis balls or racket balls depending on the tubes. & no it won't hurt the valves to have em open. Pulgging them just keeps crap out of the tubes like dirt dobbers.
    [email protected]
    Ohio
    I've been running zoomies since '97. Haven't had a warped valve yet. Problem I've had with these aluminum heads is exhaust valve seats rusting. I had 2 valves show up on a leak down test. Rust was the reason. At the end of the season I would remove the zoomies and oil the exhaust valves then back off the rockers. I'm thinking the rust may be starting while the boat sits between races with the valves set and no covers. Just a guess.
    Tim
    I think so. If you have an open ex valve, the cylinder (raw cast iron) is far more exposed to any moisture in the air (and any other elements) than with even a set of OT headers which IMO should also be covered when the engine is sitting.
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    We use WD 40 lids. They all red but tennis balls work too.
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
    waterloo
    We use hot dogs in buns. Plus when you start the engine, it launches them out as souveniers.
    Wags
    Green Bay Wi,USA
    Wags
    a little formaldehyde flavor too.
    Quote Originally Posted by rampgirlll View Post
    If you just bark it in the garage it take 2 minutes for them to all stop bouncing, and ONE is guaranteed to hit you.
    Senior Member slow67's Avatar
    DFW
    I think that is the funniest thing I've ever seen you type. I think you should hire a temp guy, hide a camera, and film it.
    Jun 2010
    Ft Worth
    Only missed pulling them off in the pits once, they flew over both rigs parked on either side of us! Oopps
